Old 06-01-2001, 02:28 PM
mak
Question power light?
Should the power light come on when the ignition is turned on? I just bought a beautiful "97 and I tried to call up the transmission codes unsuccessfully. I've never seen the power light come on at all! Please help while my car is still under warranty. Thanks
Old 06-01-2001, 07:11 PM
picklesbitch
owner's manual
Did you get an owner's manual with the car? This has a lot of info about the car you may find useful, like if the power light is supposed to come on when you start the car. If you didn't get one, do a search, and you will be able to find the phone number for S.O.A. (Subaru of America). Call them and they will send you one free. I'd tell you about the light, but I don't remember. I don't drive my car very often any more. You also might be able to do a search on "Power light".
Old 06-02-2001, 01:21 AM
FlagstaffSVX's Avatar
FlagstaffSVX FlagstaffSVX is offline
Jedi Member
For redundancy's sake I'll be the first to say the the Power light Does come on when the engine is started. (along with just about every other light on the dash, "oooo... mommy? can i play with the christmas tree lights?") It is my opinion that the Green Power light is a very good complimentary color to the "faded green" illumination and orange needles.
-Craig Lowthorp, Flagstaff AZ
'92 LS-L, Black on White, 136k SOLD
'92 LS-L, Black on Silver, 120k SOLD
'01 Legacy Outback, White,
Old 06-03-2001, 01:28 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
I'm not positive -- This would be a question for Larry III, who has a '97 -- but, I think the power light was disabled on the 96/97 MY's. Not the function, mind you, but the light. Seems like I've heard that before. Ask Larry to be sure.
Randy Johnson
Mike Davis -- at Reading VI
Old 06-04-2001, 08:56 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
Don't worry about it till it blinks. Mine is blinking 16 times and I am slightly worried. I am smelling trans fluid burning as well.
Lwin
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 06-04-2001, 09:25 PM
picklesbitch
trans fluid?
Are you sure it's trans. fluid? The SVX has a habit of leaking oil from the front seals, draining down under the engine onto the exhaust. Minor leakage makes great(?) smell! Good luck,
Mike
Old 06-04-2001, 10:15 PM
Aredubjay's Avatar
Actually, though, it would have to be, at least, connected to send tranny codes. Hmmm. Larry, enlighten us.
Randy Johnson
Old 06-04-2001, 10:20 PM
Aredubjay's Avatar
Lwin
One place to look for a tranny fluid leak would be your cooler hoses running from your stock cooler (in the radiator) back toward the engine. That's where my "billowing smoke" was coming from, shortly after I got the car. Check also to see if your Power Steering O-ring (between the reservoir and the pump) is leaking (you'd see a puddle of fluid on top of the engine, behind the pump and under the manifold). And one more place to check would be the Power Steering return hose.
Randy Johnson
