oil pump gasket replacement cost
Hi,
just wanted to know how long it should take to replace the oil pump gasket - mine is leaking. Also what is the approx. cost for the actual gasket?. thanks
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. |
Re: oil pump gasket replacement cost
the oil pump has a o ring and uses RTV sealer ,if you can do T belt you should be able to fix it replacing the front seal should be done to along with sealing the rist pin access plugs
most dealers i have worked for charge around 3 hours for a belt and another hour to reseal the pump ,one other note be sure to check the screws on the back of the pump to make sure there tight,the crank seal is under 10 and the o ring is under 5 dollars Last edited by trophy956; 06-18-2017 at 09:56 AM. |
