SVXBot
Old 04-09-2017, 05:52 PM
I have too many parts and not enough money!
Hi Guys,
I have been hoarding Subaru SVX parts since 2001.
I need to sell some of this booty off.
Some of this stuff is brand new, most of it is used.
All of it is presentable and useable.
No, I don’t have any radiators, cam/crank sensors or TPSs to sell.
I have some doors, fenders, trunk lids factory spoilers that need to be repainted, a hood, a brand new factory muffler (all years), a brand new two into one center cat, (96 &97) some interior stuff. Starters, factory fresh head gaskets, one brand new alternator, intake manifolds without IRIS valves, throttle bodies,ECUs, TCUs, ETC, ETC, ETC. Bill’s already LSD’d R160 4.44 that does not whine!
I have a 28’ X 24’ garage attic COVERED with Subaru parts! If you need something, please ask.
I need to make some room, and I need the money.
three oh one seven oh seven three four three seven
Thank you, Tom Krynock aka svxfiles
Old 04-23-2017, 02:06 PM
LarryIII LarryIII is offline
Re: I have too many parts and not enough money!
Tom,
I'm going to send you a PM for the parts I need/want.
Larry III & The Beautiful Naviguesser
'17 Tungsten Pearl Outback 3.6R Ltd...."AISHA"
'07 Gray Diamond Pearl Outback XT Ltd..."AH SO"
'97 Bordeaux Pearl SVX LSi..."SUBYDOO"
'94 White Pearl SVX LSi..."PEARLY"
'92 White Pearl SVX LSL w/touring pkg..."SVXY"
'92 Teal SVX LSL w/touring pkg..."ALCYONE"
Engineers do it with precision.
English teachers are novel lovers.
Home: larrysingeriii@comcast.net
SVX FEVER, CATCH IT AT A MEET NEAR YOU !!
Old 04-24-2017, 06:07 AM
theflystyle's Avatar
Tom - PM Sent!
1994 SVX LSi
1994 Legacy L
WRX Wheels
2008 Legacy 3.0R
HID, Bilstein F/R, WhiteLine LCA Bushings, Potenza RE970AS PolePosition Tires
Old 05-11-2017, 05:05 PM
flmont flmont is offline
I need a set of engine mounts,.??? Thanks Frank
Old 05-14-2017, 06:35 PM
Hi Frank, do you want stock SVX mounts or MUCH heavier duty ones? three oh one seven oh seven two eight three seven...
Old 05-14-2017, 07:29 PM
Drivers side rear hub assembly and/or a drivers side engine mount? Shipping would be crazy id imagine but id be willing to meet somewhere in west va or if you are available my engine could use a reseal...
Old 05-14-2017, 07:36 PM
"Drivers side rear hub assembly" I actually might have a brand new one in the parts attic! Just gotta climb that ladder.
Old 05-16-2017, 09:30 PM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
Tom - Sent you a PM, haven't heard back. Do you think any of those parts would be of interest for my new build?
95 LSi Red, 16,800; bone stock for now
94 LS-i Emerald Pearl, 102,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; FrozenRotors slotted rotors fr&r; Cadmium plated calipers; SS brake lines, Axxis Ultimate pads; Rota Boost 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light - sold
Old 05-22-2017, 12:16 PM
ShiuludeSVX's Avatar
ShiuludeSVX ShiuludeSVX is offline
Send a message via ICQ to ShiuludeSVX Send a message via AIM to ShiuludeSVX Send a message via Yahoo to ShiuludeSVX
Is the alternator a beefed version, or the stock?
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 05-23-2017, 10:40 AM
DallasSVX92's Avatar
DallasSVX92 DallasSVX92 is offline
Do you have a drivers side fender? In black?
Old 06-06-2017, 12:15 PM
Austin Austin is offline
Tom,
You got any seats? I'm looking for a tan passenger seat.
Austin
__________
'97 LSi Ebony - daily driver - mostly just needs body work [couple o' rust holes, door dings, and peeling clear (of course)]
'96 LSi, Laguna Blue (retired - leaks from every possible location and some impossible ones too)
'89 XT6 5 speed (Gone but not forgotten)
'06 Tribeca (so many little disappointments it's nearly turned me off of Subarus - nearly)
Old 06-10-2017, 10:45 AM
rrhenderson's Avatar
rrhenderson rrhenderson is offline
MacArthur
Hi Guys,
Hi, Do you have SVX Ignitor? Need one. Thanks.
Old 06-10-2017, 01:27 PM
SoCoNoHa's Avatar
SoCoNoHa SoCoNoHa is offline
I have not enough parts...or money
Hey Tom, would that 2 into 1 cat work on an obd1?
Raiju - 1992 SVX LS-L Pearl White: '99LGT 5MT, '99LGT Brake Booster, Custom Short Throw, EJ251 FPR
Old 06-15-2017, 06:48 PM
wolfcj wolfcj is offline
Re: I have not enough parts...or money
Sent you a PM about a couple of things I'm looking for.
Rate This Thread:
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
