#121
Re: Phenolic Intake Manifold and TB spacers for the SVX/EG33 coming soon
Hello SVXers- I will make these things anytime I get an order. Got material to make a couple more on-hand at the moment. You can use your existing EGR tube, you just have to tweak it a little to get it to line up. https://www.facebook.com/pages/X35-D...19198304830633 and http://www.x35design.com/ That's my FB page with a crude video on how to bend the EGR tube. Links for purchase are also there, etc.. Glad to see someone else get these installed, and that they are working as intended.
#122
And so it begins.........
#123
I'm afraid so. Can't help myself. Have to keep it automatic, this time, and emissions compliant, and able to traverse a pothole without sending me to the dentist. But, who knows might make the /Drive channel one more time. Won't make Bring a Trailer again unless it goes up for sale and I won't do that if I can restrain myself enough to keep it viable as a daily driver.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
#124
Oops. Said I have a '94. Freudian slip. I now have a '95. The past is past. Forward, into the future.
#125
Well Dan the spacers are one option/upgrade that actually helps efficiency and promotes longer engine life, at least those under manifold hoses and sensors.
#126
Re: Phenolic Intake Manifold and TB spacers for the SVX/EG33 available
After painting my engine cover to match the manifold, I put my final "cherry on top" to only notice the new gap that exists because of the throttle body spacer lol. It never occurred to me until I saw it sitting there. Its not that bad. My wife didn't even notice until I pointed it out to her.
On another thought. Would it be beneficial to create a spacer for the EGR tube where it meets the manifold? I am not sure how much heat transfer happens from the tube but it was just a thought during reassembly.
#127
Thanks to you last couple of guys who ordered your spacer kits. They are going to the mail on Monday
Now for a blemish sale. I have one set, from my initial messing around, where I made a couple of small cosmetic mistakes to the set. I think you could use them as they are, but they are not pretty enough to sell at normal price, so I'll blow them out for just $80 shipped. That will include the necessary bolts for installation as well as the US shipping cost. For the TB spacer, the line along one edge of the spacer was not cut straight. For the Mani spacers, on each there is an 'notch' cut out of them. You can see them on top of the gasket to see what's missing. You could fill this with some sort of epoxy, or just put them on and probably be OK. See the pics. Contact me steve@x35design.com if you want to buy them. First email in gets them. I will update when they are sold.
'93 Anniversary Edition SVX 122k - 3.7 FD 5MT Swap, ECUtune 1a1, Bontrager RSB, Mad Restoration underway! '20 Honda Ridgeline Custom Oil Caps, Battery Bars, Phenolic Spacers for sale here: http://www.x35design.com Last edited by Stevebsy; 05-31-2015 at 04:20 PM. |
#128
Sold!
Thanks!
#129
You can still see it listed on his website. Not sure if it reflects actual stock or not.
#130
I can make a set anytime. You can order thru my website.
Not sure if I have the material on hand at the moment but it is only a couple days to get it in, if needed.
#131
or does it include the upper intake too? Reason I ask is I dont need the throttle body spacer but i can get that one if the other does not include the upper intake. Also are you still planning on making the battery hold down? I did not see it on the website. |
#132
The battery tie down will come someday, when I have some free time to R&D a couple on the mill, not sure exactly when...
#133
After much delay, I will be offering these spacers again.
Should be up on the website sometime this week. May change to 1/4" or 3/8" thickness due to greater materials availability, still thinking about that one.
#134
On The Racer I have both 1" top and 5/16 on the bottom. Even with race weight hood with no under hood bracing, the manifold still rubs the hood.
3/8" would be great, imho. Tom
#135
by the way it was great to meet you at the tail of the dragon My wife and kids want to go back, as do I, if we can. |
