Old 01-05-2009, 12:37 PM
TurnInConcepts TurnInConcepts is offline
transfer clutch - that's not right...
So I'm betting that this isn't right....
Does anyone happen to know the part number for the gear/clutch center?
Old 01-05-2009, 12:41 PM
bheinen74 bheinen74 is offline
Re: transfer clutch - that's not right...
the rest of the gear that has separated, pulls out of the tranny. And, are you saying, the clutch packs inside were mia too?
anyhow, I would just find a used one and rebuild. They are not supposed to come off like that.
the rebuild clutches are less then 50 bucks
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 01-05-2009, 01:19 PM
We already have it out of the tranny. I just need the part number if anyone has it. I'd hate to call Jamie and try and explain this part to her.
Old 01-05-2009, 01:40 PM
Those parts are PRICEY!!
The sun gears are matched sets, so it is not as simply as replacing it. The sun gear on the pinion needs to be changed as well.
To get the parts new costs upwards of $500 just for the sungears, then another couple for the clutches if you want to replace them.
This failure is usually cause by inproper installation of the thrust bearing or excessive wear of the bearing. Not uncommon and many times leads to the destruction of the front differential as well. If I were you, I would try and source the parts used and replace the thrust bearings w/ a new one of the appropriate size
Old 01-05-2009, 01:53 PM
Oh! Good call. Thank you for the tips Tom.
Old 01-05-2009, 02:14 PM
Maxo's Avatar
Maxo Maxo is offline
That happened to my '92 too. I was able to replace the parts but my tranny went a few days later probably due to all the debris from the sheared clutch basket. My atf was pretty dirty looking and the fluid flush I did probably made it worse.
Anyway... I have all those parts including 6 very new transfer plates. PM me if interested.
Old 01-05-2009, 02:49 PM
longassname's Avatar
Just some dude.
Significant Technical Input
31450aa260
Old 01-05-2009, 03:07 PM
Our fluid is looking pretty good. I was worried about debris when I took it apart.
Shoot me a list of what you have, and what you want for them.
