Old 08-10-2004, 01:18 AM
The Molinator
BEST TIRES? for SVX?.....ALL SEASON
Please let me know what you think are the best all season tires for the SVX. I have Dayle's drop spring (1" front, 1/2" rear) and Koni insert package (love it!, BTW).
A while ago someone said the Hankook (??model) 245x40x16 tires were the best! I do tend to like the slightly oversized tire idea, if it will clear (and no other problems)!
Please share your preferences, I suddenly need tires SOON.*
THANKS FOR YOUR INPUT!
P.S. MY rear tires are severely bald on inside edges only. Is that camber? I just (4 months ago) had 4 way alignment at very reputable brake/alignment shop!
Jim
Old 08-10-2004, 11:19 AM
mbtoloczko's Avatar
sans SVX
I've heard that the Continental ContiExtremeContact is very quiet and has very good performance. Should work excellent in rain/snow. Another tire I've heard good things about is the Toyo Proxes 4 all season UHP tire. Only negative I've heard about this tire is that most people think it would have marginal performance in the snow (compared to other ASUHP tires).
Worn edges could be caused by out of spec camber or by out of spec toe. Did you install camber adjustment bolts in the rear? IMHO, "reputable shop" is almost meaningless these days. Did they give you a print out of the final alignment values? If not, you should go back there and get it. Proper specs for the rear are +/- 0.125" of toe (with 0 inches being preferable) and around -0.6 to -1.2 deg of camber (with -1 deg being a reasonable comprimise between performance, and non-uniform tire wear).
Mychailo
Visit my locker
Old 08-10-2004, 11:41 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
For the money, Sumitomo HTZ+ all season tires are hard to beat. They run just $59 at the TireRack, are W speed rated and perform well in the snow...
Here's a link to the five most common tire choices for the SVX at the Tirerack: Tires - Best Sellers
-Chike
2006 Steel Gray WRX TR (sold)
Old 08-10-2004, 11:56 AM
n00b on demand's Avatar
i have the sumitomo's and their awesome! I got mine for 80 bucks a peice though. You could probably get em cheaper. I think mine are H rated too. Mine has about 4 or 5 k on it and alottttt of tread left.
Old 08-10-2004, 02:19 PM
I really like my Akurets.
Old 08-10-2004, 02:22 PM
tancred
I will go with my Ventus VE105s....Stick to the road something fierce and the way I drive, that deserves a trophy, i can get them to break loose and scream but its a very controlled feeling, no "Oh ****" slides into objects, just pure road hugging love, havent had them for winter yet, but after looking at the tread pattern i think they will do really well.....at 109 a tire for stock rims, I cant argue either....
Old 08-10-2004, 03:37 PM
TIRES
I have Sumitomo HTR+ all weather tires, Z rated for around $85. They are for 17x8 wheels so i think it was a good deal. They wear very slow which was a strong incentive to buy. The only complaint i have is over 75 0r 80 mph on the interstate i get more of a vibration than i would like. I'm guessing its the tires but i could be wrong. Overall, they rate high in every category. Check tire ratings on the tirerack to get a better perspective. I had bridgestones twice. The original v-rated tires were great but were not available when i needed new tires. The Z-rated ones wore unevenly and didn't last 13,000 miles and were expensive.
Good Luck.
Mike
95 Pearl Blue L
Old 08-10-2004, 03:43 PM
mbtoloczko's Avatar
sans SVX
Re: TIRES
I've got the same tires on 17" rims. Grip is good on wet/dry/snow, but the tires are incredibly loud compared to the Dunlop Sport SP5000 tires that were on the car previously. No vibration at speeds up to 125 mph.
Mychailo
Visit my locker
Old 08-10-2004, 04:02 PM
tancred
Dunlop SP5000...Seperated the belts in 4 complete sets and had flat tires ofter...4x4 = 16 flats.....Big O Tire had to keep giving me replacements..
Old 08-10-2004, 06:39 PM
svx_commuter's Avatar
The Continental ContiExtremeContact is great in the snow and rain and quite and nicely priced. With those great qualities something has to go and that would be the dry traction. So if you don't want to win at auto-X it's a good all year round tire IMHO. Then again maybe auto-X could be run in the rain or snow. The SVX would kick some a$$ then.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 08-10-2004, 06:59 PM
There are around 5 sets of Continental ContiExtremeContacts out here in Washington. They are a very good tire for the money ($114.00 ea) and are very quiet.
Old 08-10-2004, 10:21 PM
halistan's Avatar
halistan halistan is offline
Grand Poo-Bah
Send a message via AIM to halistan Send a message via MSN to halistan Send a message via Yahoo to halistan
I have the continentals
I wouldn't recommend them. I think they suck. They are terribly loud, the dry traction isn't so great and no matter how many times i get them balanced they feel like they are off. I paid $89/each for them and i can't wait to get rid of them. I had the Pirelli 7000 supersports and the Yokohama decibels. Both were good tires but I prefer the decibels. Nice smooth quiet ride.
I would just stay away from the Continental extreme contacts though.
'93 LS-L named "Samantha Victoria Xavier"...Sam for short.
All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter.
Old 08-11-2004, 08:50 AM
AFBeefcake's Avatar
Subaru Swapper
I run the Continental ContiExtremeContacts when I don't have my summer wheels on my car and there great. They do feel off balanced for the first mile or so after letting the car sit over night, but after that there fine. There diffently better the the sp5000 I had before.
2005 Legacy GT
My WRX's Cardomain Page
Old 08-11-2004, 02:24 PM
Several members as well as myself have noticed the same thing about the tires bumping a little when you first start out. I have not driven real aggressive with them, but I really like them. They are great in the rain and snow. I still think they are very quiet.
Old 08-11-2004, 03:35 PM
The Molinator
HANKOOK ??????
What about Hankook tires? Someone raved about these before....but I lost the thread...
they said.... 245 45 16 would fit!...... AND function well too!
BUT...I CAN'T REMEMBER NAME (MODEL) OF TIRE???
THANKS for your help!
Jim
