Old 07-14-2004, 09:32 AM
alacrity024
trunk won't pop
the trunk release handle doesn't work anymore and the key i have won't fit the trunk lock for some reason. i can access the trunk through the backseat for now, but that's not exactly convenient. where do i start looking for broken cables in the release mechanism?
Old 07-14-2004, 09:46 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Do you have a spare key for your SVX lying around at home?
My valet key (has a 'Y' on it) doesn't open the trunk latch, but my 'X' key does.
Once you're able to open the trunk, see if the trunk lock switch hasn't been activated on accident - it's a little lever on the lock itself.
If that isn't the problem, remove the plastic covering surrounding the latch (at base of trunk). On the right hand side you'll see where the metal cable runs and releases the lock. If that metal cable is gone, pull your trunk siding and look for the metal cable.
-Chike
2006 Steel Gray WRX TR (sold)
Old 07-14-2004, 10:00 AM
dcarrb dcarrb is offline
Originally posted by Chiketkd
My valet key (has a 'Y' on it) doesn't open the trunk latch...
For those who don't know: It's not supposed to.
dcb
Old 07-14-2004, 10:29 AM
Chiketkd's Avatar
Why??? My three keys are the original ones the previous owner got when he bought the car new...
-Chike
Old 07-14-2004, 11:11 AM
Think about what a Valet is. Do you want him or her to get into the trunk and rummage through your stuff? I don't. That is why you would give them the valet key so you could be sure they couldn't get into the trunk - just park the car and bring it back. (As if I would let someone else drive my car when I am not there !!!!!!)
I would bet that the Cancel lever is moved to the up position on the trunk latch. It has been done many times and is very easy to do. Move it to the down position and it will work again. Why would you want to do that? Same reason as before. That way the Valet can't get into the trunk without the regular key.
Old 07-14-2004, 11:34 AM
Of course, you do have to cancel the remote trunk release before leaving the car, and an unscrupulous valet could still gain access to the contents of the trunk through the back seat.
Pretty sure the valet key doesn't open the glovebox, either.
dcb
Old 07-14-2004, 11:50 AM
Mr. Pockets's Avatar
Moderator
dcb
No, the valet key does not unlock the glovebox.
As for the back seat, isn't there a leve on the back of the seat to disable the button? I haven't looked at it in awhile, so I may be thinking of a diffrent car.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 07-14-2004, 11:56 AM
Chiketkd's Avatar
Yes, there is a lever that you need to push first (on the back of the seats) before you can flip down the backseats from inside.
-Chike
Old 07-14-2004, 12:20 PM
Yep; forgot about that.
dcb
Old 07-14-2004, 12:24 PM
Chiketkd's Avatar
Question dcarrb - does your key(s) not have a 'y' or an 'x' marked on them???
-Chike
dcb
Old 07-14-2004, 12:36 PM
My regular key is an aftermarket dupe, but it does in fact bear an X_ _ _ code. Valet key is stashed at home; I'll check this evening.
dcb
Old 07-14-2004, 03:34 PM
NeedForSpeed NeedForSpeed is offline
My worst
NIGHTMARE,
Both Subaru keys broke within a couple weeks of each other. The keys were probably ten years old. One key actually fell off just before my exwife put it in the ignition. Then, I believe it was her again [no comments please] broke the other key in the trunk lock.
Well, that was okay for awhile, until somehow both the rear deck switch that prevents the pull handle from opening the trunk and the switch on the rear seat that prevents the button from releasing and folding the rear seat down got switched. I think the rear seat switch got moved somehow when the seat was down.
Well, thankfully, a talented locksmith got the broken key out, and it was way in there! Then, using the new keys I had made I opened the trunk and flipped both switches to allow full access.
My advice, if your keys are old, have them replaced. They do fatigue over time.
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 07-14-2004, 07:54 PM
Chiketkd's Avatar
Ouch! Sorry to hear about your ordeal Ron. That's funny how both keys broke with your ex-wife...
-Chike
Old 07-14-2004, 09:42 PM
SVX-FF's Avatar
SVX-FF SVX-FF is offline
Live it, Love it, Breathe it
I went to the Subie dealer to get two new keys cut that had the black on the key. They had to cut them by code, 3 times. the darn keys still did not work. the key code on mine has been recycled or somthing. The dealer could not cut the keys normal because of to much paperwork. Lazy people. I had to get two ugly spairs made at Ace Hardware for 5 bucks. But they work
Steve
03 Ford Expedition(hers)
Are you in?
My Old Locker
A 4.11 Founding Father
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
Old 07-15-2004, 12:10 AM
Keys
Steve
This happened a couple years ago, keys breaking within a couple weeks. When the second key spontaineously broke in her hand as she was reaching for the ignition. It just fell off!, thankfully before my ex-wife got it in the ignition. Actually, THAT would have been the WORST nightmare. Imagine, one key broken in the ignition, the other broken in the trunk lock! Anyway, The car was at the grocery store. She called me for help.
Now, I had no keys. One broken in the trunk lock, now the other just a stub! So I drove to the closest Subaru dealer, and had five keys made with the black grip. I believe the key code was used, the code recessed in the key near the grip. Then, I drove another 50 miles back to the car. I put the first key in, it would not turn. Again with the next key, a no go. Luckily, the last key I tried started the car.
Well, I had another Subaru dealer cut some keys using the VIN. These keys came out differently, the cut looked different. More key was left between the whatevers? The keys looked stronger. Anyway, every key worked. I took the other keys back to the first dealer and got my money back.
How about that? Well, the groceries were in the trunk, so the flip handle was still working at that time. Sometime after that, both switches got locked, and I couldn't get into the trunk. So, while playing at Lake Tahoe for a few days, I found this locksmith. I think it took him almost an hour to dig that key out. He had several picks in there holding all the shutter doors open [or whatever they are called]. Finally, all was well again with my Subaru.
