Old 03-15-2009, 01:27 AM
techy101's Avatar
techy101 techy101 is offline
A.L.I.C.E.
Send a message via AIM to techy101 Send a message via Yahoo to techy101
A few more questions...
Yup, more questions from Techy.....
First,
How does this look in the cylinders? It's my first time so I'm not 100% sure what I should be looking for. Is the crap that is on the piston supposed to be there? Can/should it be cleaned off w/o tearing the whole thing apart?
Second,
How does this cylinder look? Ben mentioned to look for scoring, but I'm not sure what exactly that is. I assume it means some kind of scratching.
Third,
What is the best way to clean off the goop from the old head gasket, etc... I tried a light scraping on a very small section but it looked like it put a few very very tiny scratches into the aluminum so I stopped.
ALICE: 2005 Forester XT (Ice Racing Machine)
River: 1992 SVX LS-l 125,000 # 0930 (getting fixed up at the moment)
Old 03-15-2009, 07:06 AM
Re: A few more questions...
Those cylinders look to be in beautiful condition. You can still see the cross hatching from when it was honed.
I think if you use a bit of heat (heat gun) and a plastic scraper the old gasket material should come off. Maybe some solvent for a final cleaning.
Old 03-15-2009, 01:04 PM
jakea jakea is offline
EG33 Impreza RS
looks real good, but the bearings will go far sooner than issues with the walls.
2000 Impreza RS-EG33
1995 Impreza L-ej22
1992 SVX LSI- gutted and scrapped
Old 03-15-2009, 01:15 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
the cross hatching you see is fairly typical for EG33 engines in the 150k mile "age". What you'll want to do, assuming you can borrow the right instrument (internal bore guage) is check to see how "in round" the cylinders are and to what extent, if any, they've developed a taper (variance in ID as you move down the cylinder). Since you already have the heads off, it's too late to do a leak down check (you might still want to consider doing one once you've got the heads back on). Given the concern that LAN and YT have voiced regarding the rod and main bearings, I would suggest looking into checking/replacing them while you've got the engine out. While I'm not necessarily recommending the "blue printing" approach that LAN takes (mandatory use of a machine shop to do it right and the $$ that go with it), you could at least go the plastigage route to see if anything is seriously "going South".
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 03-15-2009, 01:32 PM
techy101's Avatar
A.L.I.C.E.
-Bill
What are the concerns with the bearings?
Old 03-15-2009, 03:28 PM
SVXRide's Avatar
they can be set up too tight from the factory, which shows up under "extreme" loading. If you check out LAN and YT's threads, you'll see they recommend staying away from the tight end of the specs in the shop manual.
-Bill
Old 03-15-2009, 04:12 PM
If they are not making noise at 100k... They are not too tight. I would really worry about the bottom end too much unless you had previous concerns (rod knock, or crank walk). You can clean up the pistons by bringing them to the top of the bore and using a vertical drill wire brush with some engine top end cleaner. Make sure you flush the oil and coolant out of the engine after everything is reassembled to get rid of any debris you may have let get by you. Take car in what you do in regards to surfaces of the cylinder walls and the block's deck.
Old 03-15-2009, 10:12 PM
techy101's Avatar
A.L.I.C.E.
Ok, adding another question into this mix.
It's about the things that are behind the valves (the metal disk things, sorry I don't know the name). Most of them fell out of one of the heads and I put back in, but if I am going to flip the head over to remove the old gasket, they'll all fall out I think. Is this ok? I'm not sure what the arrangement was so I'm sure they're not in the same place
Thanks!
These little disks that the cam hits.
Next question, how the hell do I remove this sprocket? If I'm not mistaken, I'll need to get it off to remove the oil pump.
