Brake bleeding
Has anyone out there used the Speedi-bleed power brake fluid bleeding system? http://www.vq-speedi.com/
It looks to be a fairly effective way to bleed the brake/abs system using only one person. I know some shops use this or a variation of it.
I haven't tried that system, but I have a set of Russell Speed Bleeders on my SVX. These things have a spring loaded stop ball in the bleeder screw, so you don't need someone down at the bleeder valve to close it every time you pump the pedal. They replace the original bleeder screws. They work great. You can get them at Summit Racing.
I saw a similar item here for $7.00 each plus a shipping charge of only $3.00 /set. Looks like another way to go and much cheaper.
http://www.speedbleeder.com/
Perhaps you can convince John McKenna to build you one of his famous "Frankenbleeders."
They are also available in 303 stainless steel for $15.00 each
why do you want to bleed them?
Do you know what size the SVX uses? I was going to order a set, and I thought if you knew, I wouldn't have to go out and try to decide myself. Thanks
The brake fluid should be flushed once a year.
Was that RJ I saw up there.
It is a 10mm x 1.0 thread and measures 1.37" (34.95mm) in overall length
Thank You John. That is very helpful.
