Old 10-11-2010, 09:57 PM
Banned
Headers Feeler
So as it is with the cold air intakes, for me to go through the R&D for NA Headers it takes money. So I wanna know how many people would be willing to actually purchase them? If not enough people are interested I'll just hold off until I do my turbo kit otherwise if it's worth my while I'll do some NA ones as well. anyone??
Old 10-11-2010, 10:28 PM
Cam Cam is offline
Re: Headers Feeler
If they could he designed for my 11:1 cr setup I would he very interested. I don't know enough about exhaust to actually have any specific requests other than that, though.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 10-11-2010, 11:05 PM
SoobCrazy SoobCrazy is offline
SVX n00b
Re: Headers Feeler
I don't have the extra capital to actually vouch for a set, but depending on the design and engineering of your proposed headers, they would be on my list.
I designed the headers on my EA81T and if you want any ideas or general best practices for building headers, feel free to ask.
Old 10-12-2010, 02:10 AM
Banned
Re: Headers Feeler
here is a half assed photoshop rendition of my idea for headers and the collector pipe that would connect to a highflow cat
Old 10-12-2010, 02:13 AM
Banned
Re: Headers Feeler
it is basically a shorter version of rallybob's headers
Old 10-12-2010, 03:19 AM
I'm curious as to the benefits this would have on a stock car, or a car making a little more power than stock.
Old 10-12-2010, 07:48 AM
StatGSR StatGSR is offline
Send a message via AIM to StatGSR
Re: Headers Feeler
I know it pertains to hondas (Oh no the H word) but its still a good quick read on Header tech.
http://www.team-integra.net/sections...p?ArticleID=50
just think of it as 6-2-1s. instead of a honda 4-2-1
94 Acura Integra GSR
97 Legacy Brighton - EG33 Swap still in progress
03 Silverado 2500 - Duramax
Old 10-12-2010, 07:49 AM
RallyBob's Avatar
RallyBob RallyBob is offline
Registered fabricator
Re: Headers Feeler
You really want to run longer primary tubes than I did, with smaller diameters. For an automatic-equipped (heavy) car, torque is king. Peak HP is a secondary requirement. Shorter, large diameter tubes favor higher rpms.
Bob Légère
EG33 Impreza tweaks
Old 10-12-2010, 02:49 PM
thickasxthieves thickasxthieves is offline
Send a message via AIM to thickasxthieves
Re: Headers Feeler
A properly manufactured and developed set of headers would be of great interest when it comes time to do the exhaust in spring... im 'feelin' this
94 Emerald LS w/ awd 4.44 swap 199xxx daily driver
Stage 2 ECUTune chip, 370cc injectors, ECUTune valve body and TCU, solid rubber motor mounts from a forester, outlaw phenolic spacers, COBBTuning lightweight blue crank pulley, Bontragerworks 22mm rear sway bar & endlinks, StrongFlex poly front sway bar bushings, Powergrid adjustable front sway bar endlinks, 17" MOMO CORSE RPM wheels w/ Toyo Proxes4 225/45, drilled/slotted rotors f/r, stainless lines, ceramic pads, Blue silicone radiator hoses, power mode switch, gold jdm hood badge, 20% tint all around, Hella optilux xtreme yellow fog bulbs
parts waiting to go on car: the rest of the strongflex polyurethane suspension bushing set
Old 10-12-2010, 07:40 PM
Boxersix's Avatar
Boxersix Boxersix is offline
Porsche Autofanatiker
Re: Headers Feeler
^^Quoted for truth^^.
As a fabricator of components of this type, and a product that seems to be set towards the typical SVX owner, short tube large diameter headers would not be the best approach.
Take it as it is though, it is your product so design and make as you see fit.
Old 10-12-2010, 09:07 PM
Re: Headers Feeler
Ok, but where does the factory setup stand in all this? Is it tuned for low-impact comfort like everything else or does it have it's performance advantages?
Old 10-13-2010, 10:07 AM
Re: Headers Feeler
So these headers will do away with the front cats and end where the main cat is? How will it effect the o2 sensors?
Old 10-13-2010, 10:09 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Re: Headers Feeler
If I was shopping these up, I'd love to see bungs for wideband and EGT.
Old 10-13-2010, 10:49 AM
Re: Headers Feeler
^ extra bungs for Widebands is an excellent idea.
Old 10-14-2010, 12:24 PM
SVX n00b
Re: Headers Feeler
Has anyone considered marketing sets of OEM ex. manifolds that have been extrude honed? You would have the heat retention (cast), factory fitment, and FHI engineering that went into the OEM manifolds, but dramatically improve the flow.
A single set would cost over $400 for the individual consumer, but a set of 10 or more could probably be had for a significant savings.
Not trying to hurt business, just trying to save in startup costs and offering ideas. I'm pretty new to the community, so I don't know if this has been offered as a solution yet.
