Old 05-04-2009, 03:22 PM
JACOBBOCAJ's Avatar
JACOBBOCAJ JACOBBOCAJ is offline
Re: Transmission Questions?
the problems are back rear end is horrible shaking and still get the occasionally jerk at stop to accelerate (still not everytime). would the 1 – 2 one-way Sprague clutch cause the vibration. i can feel it through the steering wheel and the seat.
checking and changing the fluid in rear differential also checking ujoints, motor and trans mounts this weekend. im going to order the b&m Hi-Tek Automatic Transmission Cooling System, trans temp gauge, and royal purple trans fluid (can someone send a link to how and where to mount the cooler in the fender. cant figure out how to seach any threads just says sorry....) i believe these problems are linked because they come back at the same time.
Old 05-04-2009, 11:00 PM
longassname's Avatar
Just some dude.
I wouldn't spend the money on the royal purple fluid. I wouldn't even change your fluid if it doesn't look bad.
You should probably check your throttle position sensor voltage.
Old 05-17-2009, 10:17 PM
JACOBBOCAJ's Avatar
well the feeling has worstened. i changed both the front and rear differential fluid. i took the rear differential out and changed out the seals differential is clean no major signs of wear. doing the 15min mod tommorrow. just because it $15
Old 05-17-2009, 11:08 PM
JACOBBOCAJ's Avatar
well been doing some looking around after figureing out how to use the forum.
this sounds alot like my problem:
http://www.subaru-svx.net/forum/show...ight=vibration
hopefully the link works if not sorry new to the forum the thead is called "diff binding/lsd additive
tommorrow going to put the fwd fuse in and see if it stops (wherever it may be). then i guess do a drain and fill and add lsd additive in the transmission.
Old 05-18-2009, 07:36 AM
Just some dude.
If you decide you want help fixing it at some point ask and I'll suggest what to do again.
Old 05-27-2009, 10:23 PM
JACOBBOCAJ's Avatar
put a limited slip additive in the transmission. put it in the day after my last post. i havent felt it since. so assumming PROBLEM FIXED!
