Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Body Modifications
Old 01-12-2009, 09:05 AM
Wikedjuggalo's Avatar
Rebuilding
Re: Black fiberglass hood now avilable.
Originally Posted by Sov13t View Post
Granted we do not have the luxury of a wind tunnel to argue this on a more scientific basis... Which car do you think is more aerodynamic ours or the legacy? Specifically at the front of the car (including the hood)
-Sov13t.
I gotta say ours. Its angled more and more gentle of curves.
Old 01-12-2009, 09:25 AM
Sov13t's Avatar
Sov13t Sov13t is offline
Because a picture is worth a thousand words:
Of course its no SVX... looks fugly... but it gives you an idea of what is going on...
-Sov13t.
Subaru SVX 94' Laguna Blue - 8.5 C/R Built Motor, 6spd
Old 01-12-2009, 09:37 AM
no need for a wind tunnel, generally, to compare the aerodynamic's between two cars simply compare the drag coefficients. The SVX is .29, a relatively low number...meaning quite aerodynamic
Old 01-12-2009, 10:35 AM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Hell personally I think adding any kind of body modification will only slow you down unless it's lighter.. Take fiberglass for example..
Never the less, it won't sway my thoughts and opinions that the SVX with a hood scoop, much like the blue one, just looks good.. Please keep in mind that I'm not one to rice out my vehicle and no I wouldn't put underglow or an enormous spoiler*cough* on my vehicle. Nor would I use chromed out 18" rims.. But the hood scoop looks hot... lol
Old 01-12-2009, 09:26 PM
sicksubie's Avatar
All I can say is that my underhood temps went down after installing a hood scoop....
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 01-13-2009, 12:15 AM
By how much?
Seems to me you'd get similar/better results with a more open bumper.
Old 01-13-2009, 01:18 PM
sicksubie's Avatar
It was around 20 degrees or so...
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 01-13-2009, 01:19 PM
sicksubie's Avatar
the hood scoop in conjunction with the phenolic spacers though were the great. My intake manifold temps fell drastically with those two 'mods'...
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 01-13-2009, 02:10 PM
Freeman's Avatar
Unregistered User
From what I understand, the water when it rains runs up the hood and just falls on the engine? Or do you filter it somewhere else? If you have a setup, please tell me about it..
Old 01-25-2009, 07:53 PM
Banned
what are 1/4 mi. time kills with the lighter hood??? is it only tenths or is it more significant?
Old 01-26-2009, 12:34 AM
Probably next to nothing. Mods like this only work when cumulative.
Old 01-26-2009, 06:47 AM
Freeman's Avatar
Unregistered User
Still, the SVX is front heavy. Wouldn't hurt to shed some of that weight you know.
Old 01-30-2009, 05:00 PM
Banned
I have a 5spd wrx tranny green intake and a custom magnaflow exhaust set up, and new lighter wheels. I haven't dynoed it yet since I've done anything nor have I taken it down the track, I'm planning on putting the hydra with base maps and suspension on next, but I'm just curious if the lighter tranny and lighter hood would really make a difference. I know the lighter hood helps bring the weight off the front and balance it more but 30 lbs isn't much of a difference. I'm just curious if anyone has noticed if they had made any significant time differences with this and other minor weight reductions.
Old 01-30-2009, 06:37 PM
Freeman's Avatar
Unregistered User
I don't yet have the hood so I can't say for sure.. But what I can say is that it is less prone to hail damage.. Also, since when is lighter not better? I'd say if you have the funds, go for it.. If not, then get something cheaper done if you want.
Old 01-30-2009, 08:17 PM
I also have the lighter tranny, lighter exhaust, lighter wheels, A/C delete, temporarily removed passenger seat, and I suspect if/when I get this hood the cumulative effect of dropping this weight will shave off .2 seconds from stock 0-100, probably all within the first 60'.
The 3.9 gearing and stage 2 software will help me a bit more, but when it comes to weight reduction what you should really be focusing on is handling. Acceleration is improved slightly but more importantly the car will roll less and probably respond more quickly. These characteristics are magnified in low traction conditions which is why I consider this type of modification.
If you want straight line numbers (and a full interior), save your money and get something that puts more fuel/air into the chambers.
