Old 04-29-2012, 11:32 AM
subaru subaru is offline
metallic wining noise
Hallo forumfriends
since a few days I hear a metallic wining noise when braking , but also when just letting the gaspedal up. It occurs mostly at warm engine . last time at an emergencystop it occurred briefly at standing still. It is not the brakes themselves, as we tried to figure out where the sound was coming from. It appeares to come from the center down under the car. The sound is defenately gone when speeding up.
Could it be the bearings of the driveshaft or in the worst case something in the 4eat?
Thanks for any help
Rinus
The Netherlands
Old 04-29-2012, 05:34 PM
oab_au oab_au is offline
Re: metallic wining noise
Rinus could it be a vacuum leak?
One Arm Bloke.
Tell it like it is!
Old 04-29-2012, 08:35 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Sounds like a cracked flexplate.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 05-01-2012, 01:06 AM
This means the end of the tranny?
Rinus
Old 05-01-2012, 02:11 AM
Tapani Tapani is offline
Rinus
No, but the tranny needs to come out to replace it. It's a sheet metal plate between the crank shaft the torque converter.
http://opposedforces.com/parts/svx/e...gine/flywheel/
Be absolutely sure if you go this route. Quite a bit of work. So do more digging.
Tapani
Old 05-01-2012, 05:46 AM
Does the noise increase and decrease with motor speed?
Old 05-01-2012, 07:36 AM
Hi
It only occurs when there is force from the wheels to the gearbox/enging. So when lifting the throttle and/or breaking
It is only when the engine/gearbox is on temperature
The sound is like a totally worn brakepad on a disk (here we say iron on iron)
It is not related to engine rpm's, just the speed of the car
I hope this helps a little
Rinus
