Old 01-13-2012, 06:31 PM
The Molinator
MAF for ReNt.. ?
Can I borrow a GOOD MAF for $50 plus shipping both ways? Got an EXTREE?? [+Deposit, of course, in case I die.. before returning your rental.. Hmmm?]
To diagnose my *%#* SVX! Ha! Running bumpy.. sometimes .. after re-soldering my MAF.. ??
Thanks, Jim
Jim
Old 01-13-2012, 09:04 PM
My original MAF is sitting alone in a drawer, pondering its existence the last couple years.
I'm not terribly interested in going back and forth with it but if nothing else turns up for you give me a heads up.
Old 01-16-2012, 02:10 PM
The Molinator
Re: MAF for ReNt.. ?
So far.. the symptoms are CrAzY! I did re-solder of MAF.. Now, it doesn't do the intermittent crash.. but, does very jerky low speed accelerations???
Does original mean you replaced it.. cuz wasn't working??
WELL, thanks for responding.. I'll check the TPS as some have suggested, but it doesn't make sense that the TPS wud SUDDENLY malfunction .. after I "fixed" the MAF.. ?? Seems to me.. must still be MAF??
Thanks, Jim
P.S. Obviously, if it worked.. I'd want to buy it. How much to buy?
Jim
Old 01-16-2012, 07:32 PM
My maf works fine, it's been pulled because I went Z32 and I have no use for it.
I would sell it for a minimal cost, haven't given it much thought.
Old 01-17-2012, 03:11 PM
The Molinator
Still can't tell if it's the MAF! Checked the TPS last nite.. seems ok.. BUT, runs about the same .. with or without the MAF connected now.. ??
Sorry.. wats Z32?
Thanks, Jim
P.S. If your price is low enough.. I guess I can just get yours.. and KEEP it .. if not needed??
Jim
Old 01-17-2012, 11:04 PM
ECUTune stage 2.
Z32 is a generational designation given to Nissan's 300ZX. It was preceded by the Z31.
The stage 2 kit requires a Z32 maf and SR20DET injectors, so I just refer to the upgrade as Z32.
Old 01-18-2012, 03:07 PM
The Molinator
IC .. Thanks for the info .. I'll keep checking things.. Still runs OK at high speeds, but jerky on low speed acceleration ?? Idles OK .. .
Thanks, Jim
Jim
Old 01-18-2012, 06:58 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Did you try the MAF spray cleaner?
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 01-18-2012, 07:06 PM
The Molinator
Yah! .. Sprayed it when I took the MAF out .. and re-soldered it. ???
Jim
