Headers Feeler
So as it is with the cold air intakes, for me to go through the R&D for NA Headers it takes money. So I wanna know how many people would be willing to actually purchase them? If not enough people are interested I'll just hold off until I do my turbo kit otherwise if it's worth my while I'll do some NA ones as well. anyone??
Re: Headers Feeler
If they could he designed for my 11:1 cr setup I would he very interested. I don't know enough about exhaust to actually have any specific requests other than that, though.
Re: Headers Feeler
I don't have the extra capital to actually vouch for a set, but depending on the design and engineering of your proposed headers, they would be on my list.
I designed the headers on my EA81T and if you want any ideas or general best practices for building headers, feel free to ask. |
Re: Headers Feeler
here is a half assed photoshop rendition of my idea for headers and the collector pipe that would connect to a highflow cat
Re: Headers Feeler
it is basically a shorter version of rallybob's headers
I'm curious as to the benefits this would have on a stock car, or a car making a little more power than stock.
Re: Headers Feeler
http://www.team-integra.net/sections...p?ArticleID=50 just think of it as 6-2-1s. instead of a honda 4-2-1
94 Acura Integra GSR 97 Legacy Brighton - EG33 Swap still in progress 03 Silverado 2500 - Duramax |
Re: Headers Feeler
You really want to run longer primary tubes than I did, with smaller diameters. For an automatic-equipped (heavy) car, torque is king. Peak HP is a secondary requirement. Shorter, large diameter tubes favor higher rpms.
Re: Headers Feeler
^^Quoted for truth^^. As a fabricator of components of this type, and a product that seems to be set towards the typical SVX owner, short tube large diameter headers would not be the best approach. Take it as it is though, it is your product so design and make as you see fit. |
Re: Headers Feeler
A properly manufactured and developed set of headers would be of great interest when it comes time to do the exhaust in spring... im 'feelin' this
94 Emerald LS w/ awd 4.44 swap 199xxx daily driver Stage 2 ECUTune chip, 370cc injectors, ECUTune valve body and TCU, solid rubber motor mounts from a forester, outlaw phenolic spacers, COBBTuning lightweight blue crank pulley, Bontragerworks 22mm rear sway bar & endlinks, StrongFlex poly front sway bar bushings, Powergrid adjustable front sway bar endlinks, 17" MOMO CORSE RPM wheels w/ Toyo Proxes4 225/45, drilled/slotted rotors f/r, stainless lines, ceramic pads, Blue silicone radiator hoses, power mode switch, gold jdm hood badge, 20% tint all around, Hella optilux xtreme yellow fog bulbs parts waiting to go on car: the rest of the strongflex polyurethane suspension bushing set |
