Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Body Modifications
Old 02-01-2018, 10:55 AM
DallasSVX92's Avatar
DallasSVX92 DallasSVX92 is offline
Adding an OEM Spoiler
Has anyone with an SVX without a spoiler, added the OEM one? I picked one up from a pick-n-pull and I’m wanting to put it on my car.
1992 SVX LS
2002 Park Avenue
2008 328i convertible
1993 GMC C1500 W/T
Old 02-01-2018, 01:34 PM
Re: Adding OEM spoiler
The positions for drilling the holes are already molded into the trunk lid. Look from inside the trunk. My body shop did it back in 1993 when I bought my pearl one. The dealer threw in one to seal the deal. A $600 option back then.
And it cost me only $150.00 installed and painted black.
Old 02-02-2018, 10:37 AM
Awesome, ill have to check out the inside of the trunk. I wonder how hard it is? I think it would be cool to mold it into the body.
1992 SVX LS
2002 Park Avenue
1993 GMC C1500 W/T
Old 02-04-2018, 04:41 AM
Actually looks nicer when they mount it a few inches more to the rear so it almost hangs over the dack of the deck. Also remember you trunk lid is going to be extremely heavy.
Old 02-04-2018, 11:54 AM
Does any one have a pic of where the holes are for the spoiler? Theres a few different spots im seeing that it could be.
1992 SVX LS
2002 Park Avenue
1993 GMC C1500 W/T
Old 03-01-2018, 11:42 AM
ShiuludeSVX's Avatar
ShiuludeSVX ShiuludeSVX is offline
Send a message via ICQ to ShiuludeSVX Send a message via AIM to ShiuludeSVX Send a message via Yahoo to ShiuludeSVX
Ill look at mine in a minute, as I did pick one off a salvage car a year ago and I'm now in a paint class, so in the process of sanding now and removing all the plastic bits.
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 03-01-2018, 12:20 PM
Originally Posted by DallasSVX92 View Post
Does any one have a pic of where the holes are for the spoiler? Theres a few different spots im seeing that it couls be.
Holes are just forward (above) of the trunk shock on each side. There are three
The Worm
_______________
No Mods, 33K Miles
Old 11-24-2018, 09:51 PM
Re: Adding an OEM Spoiler
Drill holes at the indentations in the spoiler at the RED arrows.
If you want to move the spoiler back, look at the instructions and photos in this thread by Bwana.
http://www.subaru-svx.net/forum/showthread.php?t=64610&highlight=Spoiler”
File Type: jpeg E80001C3-909B-48D8-BEDD-2F309FF095DA.jpeg (50.3 KB, 508 views)
Old 11-24-2018, 10:04 PM
in 1992, the OEM rear spoiler was an option, and added by the dealer prior to delivery. Here are the instructions.
The dealer-installed spoiler instructions tell you to drill a 1/4" (6mm) hole from the underside of the trunk through the top and then drill a 1/2" (13mm) hole from the top back down. Actually, the instructions gave the drill sizes in mm, but this is approximated.
Be careful not to drill into your car's body if you have the lid closed to drill the 1/2" hole. You can place a scrap of wood under the trunk when You lower it in case the drill bit goes through too far.
Some members have moved their spoilers back approximately 2” back farther. If you already have a spoiler installed, the holes can be plugged with plastic plugs or with silicone sealer.
The part number for the 4 nuts that hold the spoiler on is 902600009
A thin ribbon of strip “rope” caulk is installed around the two holes in the top of the trunk lid prior to mounting the spoiler. This keeps water from entering the holes, as it spreads and compresses when the spoiler is tightened down.
I personally think it looks sleeker without the spoiler. Sealing and filling the holes and refinishing is a lot more expensive (almost $1000). More faithful to the original design.
File Type: jpeg CC3D83D2-60B4-40D2-BF59-F6F9C50876D4.jpeg (82.9 KB, 541 views)
