Old 08-30-2002, 03:24 PM
DavieGravy DavieGravy is offline
Removing tranny resistor
How do you get this damn thing off?
Thanks.
Out for good.
Old 08-30-2002, 03:31 PM
Boone
Re: Romiving tranny resistor
Thanks.
Hmmm... Unplug it?
Old 08-30-2002, 03:33 PM
It won't budge. The plastic is starting to get pretty mangled up from plyers and what not. I'll soon need a new part if I keep doing what I'm doing. What should I do?
Thanks
Out for good.
Old 08-30-2002, 03:39 PM
Boone
Remove the battery so you can get to it better, even unbolt it. It shouldn't be that hard to get to the release tabs on the plug. Why are you messin' wit it? B.
Old 08-30-2002, 03:41 PM
I'ts shifting strangely between 1st and second. Also, I want to experiment with the change in shifting.
Out for good.
Old 08-30-2002, 03:47 PM
and I've only seen one release tap on the side toward the fender. when i push it in, it still does nothing. Anyway, Do I remove the postive or negative first. I know this is a stupid question but the reason I don't know is because I've been told something different everytime I've asked it.
Out for good.
Old 08-30-2002, 05:10 PM
nubs's Avatar
nubs nubs is offline
Multiple Suby Owner
When taking off battery cables, always take off the negative first.
If you take off the positive first,you can accidentally hit a ground with the wrench,which is not good.
I_Alcyone_I
no need to remove the positive or negative first. Try what that guy said in the general discussion forum and unbold the resistor for better access.
Old 08-30-2002, 11:24 PM
Thanks alot for your help. I don't know what I would do without this forum. I was getting a littled frustrated there.
Anyway, I didn't notice the 1-2 shifting abnormality (I was having before) after disconnecting the resistor, which from what I've heard, indicates the resistor's going bad. So I'll probably leave it disconnected. It was surprising at how hard the shifts were afterwards though. I hope it doesn't cause long-term damage.
Out for good.
Old 08-31-2002, 01:05 AM
I_Alcyone_I
the only times i notice any hard shifting on mine is when the car is cold, I just try to take it easy on the gas during these periods.
