Old 08-19-2002, 07:31 AM
mattski mattski is offline
Wiring upgrade for high wattage headlights?
What is the highest wattage lamps that the stock wiring can handle? I am considering upgrading to 85 watt low beams and 100 watt high beams but am concerned about cooking the wires.
Mattski
97 LSi Ebony Pearl 130k Midlife Crisis
93 Legacy Wagon 180k Training Wheels
98 Outback 180k
98 Dodge Durango 120k Ski Bus
A multitude of skis to feed my need to go faster, faster until the thrill of speed overcomes the fear of death.
Old 08-19-2002, 07:39 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Save yourself a lot of frustration and get this high capacity kit for $35
http://suvlights.tripod.com/suvlightscom/id11.html
They also sell just the connectors if you want to mess with your own wiring.
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 08-19-2002, 09:00 AM
So far I've been running 100W fogs and 85W dims and no cooked wires. *knock on wood*
Old 08-19-2002, 05:02 PM
Re: Wiring upgrade for high wattage headlights?
Hi Mattski, I use 100 watt high beam, standard low. The wiring is OK, though you will have to replace the high beam relay in the fuse box. I put in a 22 amp replacement.
The other point to watch is that the reflectors are plastic so the heat from the higher wattage can cook, burn, melt the refelector. The reasion why I did not use, higher wattage low beam, When the highs are on, the car is moving fast and cooling is enought.
