Old 09-06-2004, 10:07 PM
blue thunder blue thunder is offline
Steering stiffness
Hi everyone, my steering has been getting stiffer and stiffer and occasionally when i turn sharply it like locks up for a split second. I have had a small leak coming from the two boots underneath for a long time. I used the Lucas power steering fluid and the leak is practically gone. Is a new rack job the only solution to these symptoms. I hope I painted a good enough picture. Thanks for taking the time.
Mike
95 Pearl Blue L
Old 09-07-2004, 01:20 AM
HighwayUFO's Avatar
HighwayUFO HighwayUFO is offline
After 200, it's all the same.
It may be the rack and pinion, CV axles or a horrible alignment issue. Get your CV axles checked and check your PS fluid. That is all I can think of, hope it helps.
Keith
The member formerly known as Civic_Slayer
1992 "Robins egg blue" SVX Originally Claret 147k- CURRENT
1992 Pearly 187K and climbing (11-91) #964 *retired
1992 Pearl SVX 122500 miles #86 FASTAR THAN THE OLD ONE.*SOLD
Everytime I get into my car, it always reminds me that it has POWER
Old 09-07-2004, 02:24 PM
Earthworm's Avatar
Meow!
Confirm that it is the boots that are leaking and not a loose/leaking hose.
Another inexpensive fix is to replace the o-ring that sits between the power steering reservoir and pump.
Old 09-07-2004, 03:32 PM
steering stiffness
Yes, I did the o-ring procedure around a year ago and the Subaru mechanic showed me the leaks from the boots maybe seven months ago. It would leak on the exhaust pipe at times causing smoke but as of late the Lucas stop leak seems to have stopped it after almost two bottles. Maybe I'll check the o-ring again. I just priced a new rack and pinion with the Tampa dealer at around $670.00. Thanks for the feed back.
Mike
95 Pearl Blue L
Old 09-07-2004, 04:29 PM
Mr. Pockets's Avatar
Moderator
Re: steering stiffness
Originally posted by blue thunder
...the Subaru mechanic showed me the leaks from the boots maybe seven months ago.
If you're referring to the boots on the steering rack, then I think you've had the answer for a long time. When those boots go not only does power steering fluid leak out, but dirt and moisture make their way in. Eventually this wears on seals and other parts.
It sounds to me like you need a new rack.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 09-07-2004, 05:40 PM
BoondockSVX
I find all this talk of racks and increased stiffness quite humorous.
Old 09-08-2004, 06:53 AM
dcarrb dcarrb is offline
I'm not familiar with this stuff, but I'd check to see if the manufacturer suggests a maximum product/PS fluid ratio, 'cos after two bottles, you're probably running straight Lucas. If the viscosity is considerably heavier than that of regular PS/AT fluid, that alone might cause your steering to feel sluggish. Is the PS pump making any noise at all when you turn the wheel?
dcb
