#1081
Re: SVX Engine cooling "Again & Again"
So if I'm reading this right consensus of best idea so far is enlarged cross over pipe like tom did and enlarged outlet from radiator outlet?
#1082
You got that right Johny, but you need to convert the cross over pipe to a Y pipe. Also note the additional AUX bypass taps to the heads.
The more the merrier
#1083
Your confusion is understandable. As I understood it, the most important item of the many tried, was claimed to be an increase in the cross section of the inlet tract to the water pump. The problem is that each modification was not tested separately, so that no exact conclusion is possible.
#1084
I always sit back and read the comments with interest on this topic. Given the amount of work I have put into it I need to correct a couple of statements being made.
Trevor is partly right when he says that a partly moded top pipe was used in conjunction with inlet mods. Steves buggy which operated at 7,200 rpm on a hot day had a slight mod to the top pipe but nothing like what Tom did. The big ticket changes Steve did was to the thermostate cover changing it to 50mm and increaseing the size of the pipe from the bottom of the radiator Matt ran a standard top pipe but cut into the bottom of the radiator moving the outlet to the centre to get better supply he also changed the pump/thermo cover to 45mm. Matt ran the engine up around 7,000 rpm and had no overheating issues, engine ran cool. Tom and Dan have only the top pipe changed but have moved the thermostate to the top pipe to improve flow through the bottom pump pipe. In addiation correct me if I am wrong, they are targeting a rev range around 4-5,000 rpm. This means the problem of caviation to the pump is less of an issue. Given the 100's of hour I have spent researching this issue and not meaning to offend anyone the soluation can be summed up as follows, If you are aiming to rev your engine above 6,000 rpm on a continuse bases and you don't change the inlet to the pump as well as move outlet of the radiator to the centre of the radiator and inlarge the pipe size then you will blow your engine. I am afraid to say at higher revs changing the top pipe only will not solve your problem. At around the 4-5,000 doing what Tom & Dan did will work and get you by. From my point of view I think its a lot easier to change the bottom thermostate/pump cover and move the radiator outlet then do all the work to the top pipe. Any way that's my 2 bob's worth. Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. Last edited by Dessertrunner; 07-04-2010 at 03:25 PM. |
#1085
Tom fabricated an enlarged Y-pipe and moved the T-stat to the inlet of the radiator.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
#1086
Biggest issue I ever had with your testing is none of them ran a thermostat which is required to keep an engine within operating temps for proper ring seal, thermal expansion, and to maintain the use of heat in the car. Tom |
#1087
Tom I agree we need to run a thermostate up the top like you did. In my road car I still run one in the pump and haven't had any overheating issue since the change.
Different paths or opinion are always good to find a soluation, all we need to do now is find the answer to the bearing problem before we blow more motors. Tony
#1088
Gday all,
As Tony has already explained, his mods (thermostat housing) are what eventually fixed my buggy. What I have found in preparation for a race, was that if I blocked of the outlets that I fitted to the rear of the heads, and ran the system standard (save for thermostat housing and slightly modded crossover) that temps started to fluctuate again. So now I have the larger inlet, slighty larger crossover, and 1/2" fittings in both heads with hoses running to to top radiator hose inlet. I dont run a thermostat, and engine sits constant around 75-80 deg c. This is what worked so far, but will know for sure next week when I try to race 700km non-stop? |
#1089
Maybe it has been asked before, but I'd love to see pictures of the buggy or engine if you have any. Sounds very interesting!
Jesus is the remedy 2015 Expedition EL Ecoboost Ebony Pearl '95 Subaru SVX LSi Home of the Bontrager Works 22mm rear sway bar!! |
#1090
Ill see you there need a hand throw me an email Andy @DOMS MOTORS |
#1091
Gday Andy, see you there. Can sign you on for pit crew if you like.....just in case. Have you got the keys for the spare parts shop in case we need some?
Nevin, trying to place pics, but dont know how to reduce sizes. Meantime, check out www.offroadracingaustralia.com.au to get an idea of what its all about. The MTG Griffith 700 is the race next weekend! |
#1092
see if this works?
#1093
Looks cool, but it seems as if you can barely see over the steering wheel?
#1094
ill call you during the week mate |
#1095
GUESS WHAT?..............
Engine still overheats, definately time to scrap these engines. Have improved temps significantly, can travel approx 180km now before refilling coolant, but am tired of all this when any other engine wont do this. Simpler to change engine brands than re-engineer a massive subaru design fault. And yes, I am a bit cranky The race was still fun, needed to stop after 350km due to a rear hub failure that was not serviceable/preventable-just one of those things! |
