Old 01-28-2006, 05:20 PM
BigBlueSVX's Avatar
BigBlueSVX BigBlueSVX is offline
Donate to the mod fund
Send a message via AIM to BigBlueSVX
Advice needed ASAP: sticky tranny pan
so my transmission pan started leaking after I went to a shop to get the ATF changed. When a second shop looked into it while replacing the front diff, they found the whole pan sealed off with silicone, so they said it needed a new pan and just put more silicone on. And it still kept leaking. So here is my dilemna: I have a new pan and gasket to put in to hopefully fix the problem and all the bolts are out, but the pan won't budge. It's sealed to the case, and I can't get enough leverage to pull it off, as the car is only on ramps. Do any of you have any ideas how to pull off the pan or loosen the seal? Thanks.
1994 blue FWD Subaru SVX L with 86k and the original tranny *SOLD*
My Cardomain page
Now part of the DSM crowd: 1990 Mitsubishi Eclipse GSX
Old 01-28-2006, 05:26 PM
Get the smallest hammer you can find, beat the pan edges GENTLY all along, it will eventually come off.
BE SURE YOU DIDN'T FORGET ANY BOLTS IN THERE
Old 01-28-2006, 05:48 PM
michael's Avatar
michael michael is offline
What Potholes ???
Floss it off with a piece of wire.
Wanted: Steering Wheel
Old 01-28-2006, 06:07 PM
I would try to floss it off or use some kind of thin blade. I don't think a hammer will do anything to a pan sealed with silicone. Maybe it will.
Old 01-28-2006, 07:16 PM
BigBlueSVX's Avatar
thanks for the help, the flossing idea sounds good, I'll try that next. So far I've done everything from beating it with a mallet to pulling on it as hard as I can, but I just can't get enough leverage. Even tried sticking a hot knife in between the pan and the case, and that didn't do much . Keep the ideas coming!
My Cardomain page
Old 01-28-2006, 09:47 PM
DarknessofDeath's Avatar
Inhabitant of Darkness
c4~~
no, not that...i'm sure the pan would come off and more than that...
have you tried exacto knives....though i would imagine the blades are either not sharp enough or....would snap....
small crow bar?
use a sh!t load of flat head screw drivers and stick them in numerous points and try pulling at intervals and/or combinations?
1992 Subaru SVX LS~L Ebony Pearl
1992 Dodge Stealth R/T Firestorm Red
1992 Subaru SVX LS~L Pearl White
1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD
2007 Subaru Legacy Spec B. Diamond Grey Metallic
Old 01-29-2006, 01:15 AM
Blow Torch ?
Old 01-29-2006, 01:47 AM
dmnknightomega6 dmnknightomega6 is offline
That happened in my old honda, what the shop did was strip all visble silicone or sealant around it and heat it a tad bit and pry when a little hot still. This will require a little patience. But from the sound of it you have quite a layer there......
Lots of luck
Old 01-29-2006, 08:50 AM
AvPPoW AvPPoW is offline
remember, no matter how much you drain it, there's going to be alot of ATF coming down, keep your face clear
Old 01-29-2006, 08:56 AM
n00b on demand's Avatar
It actually doesnt taste all that bad
Old 01-29-2006, 09:02 AM
Go out and get a gasket scraper. It looks like a flat blade screw driver that got the tip run over by a steam roller. Just get it up between the pan and the trans. Tap it in with a ball pien(spelling) hammer until you get some penetration. The pry down but not so much to bend the pan. Work your way around the pan until it comes off. RTV should never be used on a automatic transmission as the debri inside can clog up many things.
Old 01-29-2006, 09:49 AM
michael's Avatar
What Potholes ???
You should try a mouthful of brake fluid
Old 01-29-2006, 10:16 AM
Brake fluid in the eye really sucks. Was bleeding a clutch on my old truck and got squirted. Almost went blind
Old 01-29-2006, 12:48 PM
If you read the information on the containors, you will see that you should not drink, put in eyes, put up nose or in ears or put on your body, but I guess it is up to you.
Old 01-29-2006, 01:08 PM
brake fluid is to get rid of water.....
dry your eyeballs out....
i figure if you drink it...then you would shrivel up...
that would be something to see on video
