Shifter wont budge from "P"
Started the car, pushed the brake pedal, pushed the main shifter button, but couldn't get it out of "P". I did not hear the solenoid clicking to release the shifter either. I had to use the shift lock release thingi (pain in the a$$ on 94 and up models) to shift out of park.
My brake lights work, so i guess its not an issue with the switch connected to the brake pedal. Question is, where is the solenoid that releases the shifter ? I've read its under the center console, but anybody know where exactly it is and how i can get to it ? Thanks RB |
You may want to consult:
http://svx-iw.com/ ->SVXipedia -->Interior --->Console Shift Indicator Light Replacement Info there on removing the center console.
There is a switch that connects to the shifter, I had to jump 2 or the wires on it to get the key to release when I did the 5-speed swap...might be the way to fix it...the description of those wires are in the write up in my sig...
I had the same shift lock problem and eventually got fed up with always having to use two hands to shift out of park so I bought a used shift lock module on Ebay for like 10 bucks and spent 15 minutes installing it...problem fixed permanently. It's located under the center console by the E-brake handle.
Caleb |
Mine doesn't work all the time either. Sometimes it does, Sometimes it don't.
mine also has "touchy" days when it doesn't want to move right away.. never seems to last for more than a few seconds though
-Alex 1996 Brilliant Red LSi "Allie" +226k mi. 25,000 lb GVW Trans-Cooler Wet-sanded "cleared" Headlights Charcoal 22% Tint Removed intake resonator '95 Probe GT Wheels '97 grille "New Addition" 1992 Teal LS-L +156k mi. Status... Reconditioning |
