Old 09-30-2009, 02:40 PM
SomethingElse's Avatar
word words wording
Re: NO MORE CLICK click CLICK START..ONLY START!
Originally Posted by major7venth View Post
Question, did it act as if it had a bad starter solenoid? click, no starter turn?
yup. you can hear it click under the hood at the solenoid. There isnt enough juice at the end of the circuit.
Eric
Old 09-30-2009, 03:46 PM
BoxerFanatic's Avatar
Sounds exactly like mine...
new relay and steering column shroud install... here I come.
"What you plan, and what actually happens ain't exactly ever been similar..."
1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it.
2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan.
1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun.
Old 09-30-2009, 05:31 PM
Trevor's Avatar
Trevor Trevor is offline
Originally Posted by SomethingElse View Post
got to work..opened it up..sure enough...the spring was slightly deformed causing it to only make contact in one small area...after years of being abused in one spot it began to develope craters
Its just a plain relay the same one used for the band-aid fix 12v 20/30 amps
the #s read 0332204150
and the contacts inside the relay...
Attachment 12856
Just as I had predicted.
However I did not expect such a piece of badly designed junk, even though automotive electrics tend to be cheap and crude. My company would not have rated that relay, as capable of switching more than 5 amps of inductive load. It would have been out of the question to use same in any industrial situation.
It is up to the Subaru designers to explain why a diode is not included across the solenoid winding, so as to shunt a nasty inductive opening spike. A normally closed relay opening such an unprotected circuit, is exceptionally vulnerable.
Trevor, New Zealand.
Old 09-30-2009, 06:36 PM
You phail.... The relay is a 5 pin w/ 87a... Gonna need the right relay to do the proper test....
Old 09-30-2009, 06:49 PM
Trevor's Avatar
Who, what phail Tom? Right relay? What relay? Proper test? What test?
Trevor
Old 09-30-2009, 07:03 PM
Trevor
Trevor you are the one person here I would expect never to take anything as an absolute.
The 4 pin generic relay is not able to work in place a of the 5pin relay fitted stock. I will get a new bosch 5 pin relay tomorrow at work and try again tomorrow night.
Eric phails because he is good at it. You phail because its getting annoying
Old 09-30-2009, 07:31 PM
word words wording
Im not a very articulate person..there are only 4 pins connecting to the 5 pin relay man i gotta quit drinking...as much
I gave you a part # what more do you want? U want me to come install it too!
The band-aid relay gsodonis had installed was a 5 pin...guess he was thinking ahead
It still seems too easy to be true...all this mess we made with the "relay mod" and the repair was so dam simple....
Eric
Old 09-30-2009, 07:52 PM
Thats why I want to confirm because it is overly simple.
Thanks for keeping the eye out
Old 10-01-2009, 03:58 AM
Trevor's Avatar
The fault always was simple. The logical approach is simply, simple. Simple Simons, never simply trace a simple fault.
Old 10-01-2009, 10:58 PM
My92SVX's Avatar
My92SVX My92SVX is offline
My92SVX
Alcyone Silver Contributor
This no workie for me.. Took the relay off the ebony SVX I just bought which has no click, click trouble.. Put that relay on pearly and put the one on pearly on the ebony one.. Well, result.. Pearly still goes click , click and ebony goes vroom.. lol.. Anyhow.. I think I know what the problem on the pearly is.. I had the cover off the steering column off one time to tighten the bolts for the ingnition switch.. I noticed that the back of the ignition cylinder was/is lose.. I have a feeling that is where my problem lies. Maybe i'll look into that this weekend.
2006 Ford F-150 SuperCrew XLT 4X4 Lariat Med. Wedgwood Blue/purchased with 7 miles
2000 Dodge Neon ES Cranberry Pearl/purchased with 5 miles
1998 Ford Explorer Sport Red/Gray/purchased with 44K miles
1993 Subaru SVX LSL Barcelona Anniversary #99/purchased with 82K miles *** 89K miles as of 07/2012
1992 Subaru SVX LSL Pearl/Black #7200/purchased with 72K miles *** 101K as of 7/2012
1992 Subaru SVX LSL Ebony Pearl/purchased with 88K miles *** SOLD***
Old 10-02-2009, 06:21 AM
word words wording
Faulty ignition switches do cause the same symptoms, in my case the switch had already been replaced.
when I write the no start diag I will explain how to diagnose the starter circuit using a volt meter and doing voltage drop tests.
If you dont have a voltmeter and you want to throw parts at the car immediatly, the relay is the cheapest and easiest place to start.
Eric
Old 10-02-2009, 06:43 AM
My92SVX's Avatar
My92SVX
Hey Eric.. I was kind of crossing my fingers that it was the relay.. I really do not want to get at that ignition switch.. Plus.. I really don't want to replace it. Cause I don't want a different key just for the ignition.. I'm going to do some search on here.. However, I don't think anyone has actually tackled fixing the switch. Anyhow.. I'm sure your info will help others.
Old 10-02-2009, 08:31 AM
word words wording
you dont replace the whole tumbler assy. its just the electrical part at the end. Im trying to find it at subaruparts.com but am having a hard time.
Eric
Old 10-02-2009, 05:46 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
83131pa000 is the ignition switch part number, I think I paid like $35 from Liberty Subaru.
... but it's still clicking, so big thanks to Eric for my next project.
Old 10-02-2009, 06:19 PM
word words wording
my car starts every time.
heres linky to the part at autozone. they call it the power window relay but its the same p/n. http://www.autozone.com/autozone/cat...-+Power+Window
Eric
