Old 12-14-2011, 05:58 AM
Vettein93's Avatar
Vettein93 Vettein93 is offline
"stop lamp" light
All of brake lights are working but on the dash the "Stop light" continues to go on once I hit the brakes. Any ideas
Old 12-14-2011, 06:37 AM
Re: "stop lamp" light
http://www.subaru-svx.net/forum/show...ight=STOP+LAMP
Old 12-14-2011, 07:24 AM
Have you replaced a burned-out tail light recently?
The stop lamp checker uses the amperage difference between the trunk panel and the two body-mounted stop lights to determine if a bulb is bad. Very similar design to a GFCI outlet in your house.
If you have unmatched wattage bulbs, the difference in amperage can be enough to trigger the checker even if all four bulbs work.
Bulbs are dirt cheap so when I have one go out, I replace all four with the same brand.
This is the easiest place to start.
Old 12-14-2011, 08:02 AM
Could be low on brake fluid also
Old 12-14-2011, 08:18 AM
Not likely. The "STOP LAMP" bulb in the dash indicates a problem with the lighting circuit only.
The "BRAKE" indicator light usually means low on brake fluid.
Old 12-14-2011, 08:37 AM
OK confused as to what light he was talking about . Then I stand corrected . NEVER MIND
Old 12-14-2011, 12:40 PM
Green1995SVX's Avatar
The misinformation you've been posting lately with complete confidence is becoming insane!
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 12-14-2011, 02:13 PM
Manarius's Avatar
Manarius Manarius is offline
If I recall correctly, the "BRAKE" light will come on if the brake fluid is low. However, the "STOP LAMP" light is a quite different animal and is not related to the fluid level in the slightest.
-Jason
-Obi Wan Kenobi
Old 12-14-2011, 02:19 PM
oab_au oab_au is offline
I would not call "Could be ", a statment of "complete confidence ".
One Arm Bloke.
Tell it like it is!
Old 12-14-2011, 06:44 PM
immortal_suby's Avatar
Thread Killah
I consider myself pretty well informed in the area of general svx knowledge, and I still make mistakes here on advice. I guess I'll just stop posting as well to avoid giving the wrong advice with too much confidence.
Sheesh.
Locker Link
2015 BRZ Limited 6MT
Old 12-15-2011, 02:03 AM
Vettein93's Avatar
Thank you all for the help. I will try replacing all 4 bulbs first if that is not it I will replace the relay. I saw an older post from 2005 quoting the part number for the checker relay located in trunk. I did a Goolgle search but found nothing. Any leads on where to find it?
Thanks again
Old 12-15-2011, 07:43 AM
The stop lamp checker is located in the right side in the trunk, behind the carpeted panel, in front of the rear washer fluid reservoir. The design and mounting is such that if water gets into this area the checker relay acts as a reservoir to collect and hold water.
Relay replacement is a simple 1 plug/ 1 screw operation.
Part No. 88081PA000 ...Cost of the part is about $36.74
Explanation of this circuit
The rear stop light sensor works by separating the stop lamps into two circuits, each with two bulbs. The two center panel lights are one circuit and the two outside lights are the other.
The two circuits each go into a sensor and each current draw is measured. If it is not in balance (ie, one circuit has two bulbs, the other only has one working) the "stop lamp" on the dash comes on.
The manual tells you the only "fooled" instance. If one bulb from the center panel is burned out and one bulb on an outer light is burned out, the "stop lamp" indicator will not come on.
It has a fail-safe provision so if all four bulbs are burned out (zero current flow) it triggers the light.
If you put higher wattage bulbs in the center panel but regular bulbs in the outer lights, the imbalance will trigger an indicator even though all four bulbs light.
UPDATE
If you replace your tail/brake lights with LEDs, the light will trigger because the LEDs use next to no current, so the sensor thinks all four bulbs are burned out.
