Old 08-07-2006, 09:16 PM
prtsguy prtsguy is offline
new svx owner with a strange popping noise
made a sweet trade for a 92 svx because the previous owner couldnt find the problem or was to broke to try. I suspect it to be in the rear dif (sounds like a pos unit thats not clutching properly) . Rear wheel bearings and cv axles are seemingly good. Do I have positive traction in this thing?
Old 08-07-2006, 11:20 PM
Where is the popping noise?
Old 08-08-2006, 10:41 AM
Earthworm's Avatar
Meow!
Could be the front diff.
Old 08-08-2006, 11:11 AM
dcarrb dcarrb is offline
Yes, the rear diff is limited-slip. What one sounds like going bad, I don't know.
dcb
Old 08-08-2006, 11:51 AM
dcb
Are the tires all matched???
Sounds like you've got one tire mis matched on the rear....
Old 08-09-2006, 08:49 PM
not tires
I've put new tires on out of dire need(they were all mis matched and dangerous). the noise seems to be coming from the rear of the car when I back up or make any kind of turn. I can also feel it under the middle of the car when it happens. I did the LSD thing yesterday and some figure 8's but no luck. I know the person I got the car from and they probably drove on mismatched tires for a while, I hope thats not going to hurt me
Old 08-10-2006, 05:24 AM
If the previous owner ran it with miss-matched tires, it could have damaged the rear diff, the transfer clutches, and the front diff....
I've got a spare rear diff if you need it....and I'm not TOO far away....
Old 08-10-2006, 05:11 PM
oab_au oab_au is offline
Popping noise?
Doesn't a "popping noise sound", come from a worn shaft joint, half or tail shaft joint?
One Arm Bloke.
Tell it like it is!
