Old 05-12-2004, 09:34 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Send a message via AIM to mohrds Send a message via Yahoo to mohrds
Its about time the US looks at new lighting rules! (long)
These are the proposed changes to US regulations. They are finally going to discuss switching to ECE (E-Code) headlamp standards. Also interesting is the regulating of "fog" and "Driving" lights both OEM and aftermarket.
Doug
Raise the test voltage contained in MVSS 108 from 12.8V to 13.7V, or establish a dual-voltage testing regimen in which seeing-light regions are tested at 12.8V and glare-light
regions are tested at 14V, because the current test voltage is unrealistically low and substantially underestimates realworld glare intensities.
Lower the allowable glare intensities for low beam headlamps, particularly at (H, V) and (0.5U, 3.5L), because the currently allowable levels are too high.
Raise the allowable high beam intensity at (H, V) to match the European and Japanese maximum of 140,000 cd (nominal at 12.8V), because more intense high beams will increase visual performance in situations warranting high beam use, and will discourage misuse of high beams in situations warranting low beam use.
Require headlamps to be aimed lower if they are mounted high, because high-aimed high-mounted headlamps create severe glare to lower vehicles.
Permit low beam headlamps conforming to ECE photometric requirements, because
• such headlamps comply with the intent of US seeing and glare limits, in some cases better than their US counterparts,
• they do not appear to threaten any reduction in safety,
• they offer immediate and substantial relief from excessive low beam glare while offering equivalent or improved seeing performance,
• and they are more resistant to the safety negative effects of overwattage bulbs.
Establish stringent requirements for colorimetric, projected-area, mounting and photometric performance of original-equipment and aftermarket auxiliary lamps, because
such lamps are currently a significant and uncontrolled source of glare.
Lower the degree to which “white” illumination may tend towards blue, because this will reduce the production of inherently-glaring blue light and will also reduce the motivation
for individuals to attempt to attain a “blue” appearance with halogen headlamps.
Require automatic aim compensators (dynamic headlamp leveling) with HID and high-flux halogen headlamps, because such headlamps create severe glare with vehicle
attitude changes.
Raise the stringency of MVSS 101 requirements for the high beam telltale so that the words “BRIGHT” or “HIGH BEAM” appear with (or instead of) the ISO symbol, because many drivers do not notice or recognize the ISO symbol.
Raise the stringency of headlamp lens marking requirements so that headlamp assemblies intended for gas discharge sources are clearly differentiated from those intended
for halogen sources, because current regulations allow misinstallations to go undetected.
Raise the stringency of fog taillamp installation requirements to allow only one fog taillamp on a vehicle, mounted on the driver’s side of the rear of the vehicle, because dual
fog taillamp arrangements are difficult to distinguish from brake lamps and force following drivers to focus on glaring high intensity lights.
Raise the stringency of fog taillamp wiring requirements so that the fog taillamp deactivates and must be deliberately reactivated by the driver after low beam headlamps, fog lamps, or vehicle ignition are switched off.
1992 LS Touring (6/91) - Currently undergoing a five speed swap
Black over Claret with spoiler; 235,000 miles; Mods: 2002 Legacy 5 speed, ACT Pressure Plate, Excedy Clutch, Short Throw Shifter, Aussie Powerchip
Black over Claret with 2.5" setback spoiler; 202,000 miles; Mods: B&M Cooler
1994 LSi (4/93)
Bordeaux Pearl; 198,000 miles; Mods: Weight reduction.
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Sola lingua bona est lingua mortua.
Old 05-12-2004, 09:42 AM
mark10t
What he said............
It's about time.
-Mark
Old 05-12-2004, 09:46 AM
mohrds's Avatar
I particularly like the one where the fog lamps will be wired like the rear defroster, where they reset to "off" every time the car is turned off.
1994 LSi (4/93)
2000 Ford Excursion
Old 05-12-2004, 09:54 AM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
FINALLY!!!! I hate those morons with rear fog lights running on 85 degree bright sunny days.
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 05-12-2004, 12:26 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Looks like we will finally be able to catch up with the rest of the world!
2006 Steel Gray WRX TR (sold)
Old 05-12-2004, 02:56 PM
HighwayUFO's Avatar
HighwayUFO HighwayUFO is offline
After 200, it's all the same.
Now if we could only convert to JDM spec lenses, corners, and markers. That alone would be sweet action.
Keith
The member formerly known as Civic_Slayer
1992 "Robins egg blue" SVX Originally Claret 147k- CURRENT
1992 Pearly 187K and climbing (11-91) #964 *retired
1992 Pearl SVX 122500 miles #86 FASTAR THAN THE OLD ONE.*SOLD
Everytime I get into my car, it always reminds me that it has POWER
Old 05-17-2004, 12:53 PM
Nemesis Destiny's Avatar
Nemesis Destiny Nemesis Destiny is offline
6MT STi-ified, now with R180!
Send a message via ICQ to Nemesis Destiny Send a message via MSN to Nemesis Destiny
Thumbs up 'bout fricken time!!!
That would be great, were it to come to pass, even for me in Canada. Usually we fall into line behind American policy a few months/years later, but often it works better because we got to learn from all the mistakes made with US legislations and guidelines.
If I had a nickel for every time my eyes have been burnt from some inconsiderate **** in an SUV or jacked up hillbilly pickup behind me, or from oncoming glare from some punk with a fake HID kit... well, I'd be rich enough to do something about it.
And don't even get me started about loud car stereos...
1992 LS-L Touring, Liquid Silver w/ Black, 110k mi. "Alice." Rebuilt title. Mods: WRX 6-CD changer, 17x8" Motegi LC-12 (16.5lbs), PWR rad, Perrin LCP, JDM v.8 6MT + R180, Koni + Ground Control (325f/280r), Earthworm Bushings. Awaiting resto.
1994 LSI The legendary "Shotgun Slade" 110k mi and still going strong!
2005 Outback XT Limited 5MT, Obsidian Black Pearl, 211k km, daily driver.
1999 Mazda MX5 base 5MT, Twilight Blue Metallic, 152k km. "Twilight Sparkle" Summer daily driver!
2007 Honda CR-V, some awful shade of light green *yawn*
1992 LS-L Touring, Ebony Mica, 176k kms. Parts car. SCRAPPED.
1992 LS-L, Dark Teal, 367k km. "Wintergreen" the winter beater.*SCRAPPED due to rust*
Old 05-17-2004, 02:19 PM
Uncamitzi's Avatar
Uncamitzi Uncamitzi is offline
Member #447
Send a message via MSN to Uncamitzi Send a message via Yahoo to Uncamitzi Send a message via Skype™ to Uncamitzi
Re: Its about time the US looks at new lighting rules! (long)
Doug
/snip\
Proposed by who? Proposed when? Proposed where?
Maybe..if we all just quit driving at night.... what's there to see at night anyway?
Mitch Hansen
"uncamitzi"
This is a Dark Ride
92 Teal SVX LS-L 128K tranny swap with 4.11's
Well.. my days of not taking you seriously have certainly come to a middle .
Old 05-17-2004, 02:47 PM
Mr. Pockets's Avatar
Moderator
So the idea is to change HID lights so they don't tend towards blue. The hoped-for side effect would be that the kiddies won't want to emulate a harmful effect of those lamps. Do I have that right?
I find that concept misguided. The kids are always going to be doing stupid crap to their cars that has nothing to do with actual performance, and actually hinders it. Lighting included.
I do agree that US lighting regulations need some overhauling, but I wouldn't try to do it in the name of staving off retarded modifications. Those are going to be marketed as long as people buy them. No more blue-looking HIDs? Then they'll emulate something else that they think makes their Hyundai look like a BMW.
Angel eyes, anybody?
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 05-17-2004, 10:42 PM
UberRoo's Avatar
UberRoo UberRoo is offline
SVX Appeal
Do we really need more laws? We can do lots of cool things to our cars here in the States, (as well as some really stupid things.) Other countries prohibit many of the freedoms we enjoy with our cars. Remember sealed beams? After giving people [manufacturers] freedom to do what they wanted with lighting, things have only improved. Our current lighting still leaves much to be desired, but things have been getting better without government intervention.
In fact, those 'Angel Eyes' headlights are pretty neat looking and totally harmless, but they'd probably be disallowed with new regulation. In fact, new laws would probably just prohibit modification of the factory lights. I like LED taillights - also harmless - but they'd probably become a no-no. Those rapidly-flashing blinkers, while I do think they're silly looking, they are functional and also harmless. Chasing signals are kinda cool, but they'd also be on the chopping block. (Too distracting - or something like that.) Experimentation into the ideal light color would be retarded by new regulation, as well as alternative light sources such as HID, fluorescent, LEDs, etc.. Need I go on?
We have a few morons out there with poorly adjusted lights, but we already have laws prohibiting that stuff. The law does specify maximum wattage. It specifies where the lights must be aimed and where they can be placed on the vehicle. They restrict the color of the light depending on it's application. They also very specifically prohibit "unreasonable glare," which is up to the interpretation of an officer. I think our current laws pretty much have all the bases covered.
If anyone really feels this is a serious problem, wouldn't the logical place to start be with the people who aren't enforcing our current laws? I really wish people would stop chipping away at out freedoms. If ya give 'em an inch...
1994 LSi, Laguna Blue SVX Appeal
1992 LS-L, Ebony Pearl SVX-Rated
UberLocker
Old 05-18-2004, 07:06 AM
mohrds's Avatar
Re: Re: Its about time the US looks at new lighting rules! (long)
Submitter:
U.S. DOT/NHTSA
Richard L. Van Iderstine
Office of Rulemaking
F. R. Pub. Date:
02/12/2003
Category: Rulemaking Docket
Status: Pending
Subcat.: Federal Motor Vehicle Safety Standards
1994 LSi (4/93)
2000 Ford Excursion
Old 05-18-2004, 07:17 AM
mohrds's Avatar
Not exactly right.
The issue is that there are inconclusive studies about the color of light produced and effect on the human eye.
The higher the color, the more light will scatter on the beam fringe causing glare to other drivers. Dirt, dust, and rain will increase the scatter effect thus increasing the glare.
If it turns out after studies that a lower temp light is better for the eyes and visibility, then an allowed color range will be proposed.
Doug
1994 LSi (4/93)
2000 Ford Excursion
Old 05-18-2004, 07:52 AM
mohrds's Avatar
These are not new laws, they are updating existing laws to be more on par with the rest of the world.
There did not receive freedom, the freedom was there, it was just not cost effective to pursue. The general public doesn't accept radical change.
Not true. Lights under a certain candlepower are considered marker lights and are only restricted in color (white or yellow in front, red or yellow in rear).
That's a stretch. Modification will not be illegal if you conform to the regulations. You can do what I did and re-title you car as a custom (modified) vehicle and be allowed to do whatever you want if it matches the regulations.
Not true. Experimentation will always be done. But, perhaps with better worded regulations, experimentation will be done in the labs, not on the roads as a lot are now.
From the RFC:
Question 14: While we are aware of many studies to demonstrate and promote the efficacy of AFS, we are not aware of a single study that has been done on the effects on other drivers facing AFS-equipped vehicles or on drivers using AFS-equipped vehicles. Please identify any such studies.
not wattage, intensity.
The laws are archaic and contribute to the problem.
The freedom to glare oncoming drivers? You are blowing this way out of proportion.
Doug
1994 LSi (4/93)
2000 Ford Excursion
Old 05-18-2004, 07:58 AM
Moderator
DIZZAAAAM! D0UG PWND J00!!1!1!!
Doug, you clearly know way more about this than I care to right now, so...uh...way to go.
2005 Outback
END OF LINE
Old 05-18-2004, 08:38 AM
mohrds's Avatar
I find it a very enlightening topic!!!
1994 LSi (4/93)
2000 Ford Excursion
