Old 04-17-2006, 05:11 PM
orangeSVX
auto. seat belt in-op!!
hey,
my auto. driver side seatbelt on my 92 SVX is simply stuck open.
any thoughts on where to start? I know that my interior light still turns off when the door is shut, and the light indicating that the door is shut on the I.P. as well. the seatbelt light is always flashing on the I.P.
Thanks!!
Mike
Old 04-17-2006, 05:14 PM
Your answer lies within that flashing seatbelt light.
If you go to the SVXipedia on http://svx-iw.com there is a code checking section. Follow the procedures for checking the code then report back to us.
Old 04-17-2006, 05:40 PM
orangeSVX
hmm...
sorry, never checked for codes before. whats the DIAG terminal? im not sure how to get this code, it seams to flash quite consistant when the igniton is turned on.. im still trying to figure this out...
Old 04-17-2006, 05:42 PM
It's located behind the driver's kick panel. It's the same terminal used to check the engine codes.
Old 04-17-2006, 08:57 PM
There is a picture of it in the How-To Documents.
Old 04-18-2006, 02:22 PM
orangeSVX
cant open it...
I cant seem to open the section in the how-to Documents. i see the conector, i m not clear on what i plug into it! haha!
thanks for the help guys,
Mike
Old 04-18-2006, 02:28 PM
There are 2 blue wires taped up to the wiring. Remove the tape and use either of them to plug into the connector.
Old 04-18-2006, 02:39 PM
orangeSVX
keep talking earthworm ;)
ok got them, so it doesnt matter with one i use? and which one is the #8 conector?
thanks!!
Old 04-18-2006, 02:53 PM
Good question. I've never run this diagnostic yet and I don't have my FSM's to verify. Please submit feedback on that article and I'll update it once I have further clarification.
Old 04-18-2006, 02:57 PM
orangeSVX
got it!! :)
ok, trial and..got it! one long and 4 short flashes.
14, Rear limit switch on driver's side remains ON
now what?
Old 04-18-2006, 03:07 PM
Now you'll need to check the functionality of that switch. Again I've never done this and I don't have access to my FSM's so hopefully someone else can assist further.
Old 04-19-2006, 10:55 PM
orangeSVX
ok..now to pull off the inside A pillar garnish
ok, i guess this needs to come off to access the seat belt. any thoughts on pulling this A pillar off? anyone had theres off?
let me know, or i'll soon tell everyone what not to do! haha
Mike
Old 04-20-2006, 10:29 AM
It just pops off.
Old 04-20-2006, 10:20 PM
Green1995SVX
Take the a-pillar trim, and the interior piece beside the rear seat off. Unplug the seatbelt unit. use the tool under the floor in the console to crank the seatbelt to the back position. turn on the ignition. turn off the ignition. close the door. plug in the seatbelt. turn on the ignition. your seatbelt should now function properly.
Mike
Old 04-20-2006, 10:57 PM
orangeSVX
i will try that tomorrow thanks. im not clear where to put that tool..somewhere hidden behind the A pillar garnish?
