Old 09-29-2015, 12:27 PM
neverLift neverLift is offline
Wanted: Crank/Cam Position Sensors
Looking for known working/good condition crank position sensor #1 (vertical plug).
Let me know if you have any.
cheers
Old 09-29-2015, 12:46 PM
Re: Wanted: Crank/Cam Position Sensors
You can use the Crank and cam sensors from a EJ motor, the mounting tab is different, but can be modded to work, the sensor is the same thing, I have done this, it will work
Old 09-29-2015, 01:03 PM
Thanks, I may resort to a EJ22 sensor, but if I can I'd like to not have to modify anything.
cheers
Old 09-29-2015, 01:23 PM
cheers
New EJ22 ones are about $20 on Rockauto.com (for a 1998 Impreza 2.2).....a bit cheaper than the SVX one.....
Old 09-29-2015, 01:34 PM
Yeah! Crazy the difference for a slightly different shape of plastic.
I take it I'd need a matching plug for the Legacy sensor, and then file/slot the bolt hole to line up with the SVX CPS bolt hole?
cheers
Old 09-29-2015, 01:44 PM
Nope, the SVX wiring plugs right into it, then just turn the sensor until the SVX bolt will catch the side of the sensor (the hole is a slightly different distance out).
The sensor has no pressure on it, so the bolt is just to hold it in.
