Old 02-02-2008, 12:15 PM
Wikedjuggalo's Avatar
Rebuilding
Sub woofer and Amp write up
I wanted to make my write up available to anyone who has questions on how to do it. The link in my sig is where you can find it. I tried my best to explain everything in it.
Old 02-09-2008, 03:18 PM
SVXdc's Avatar
SVXdc SVXdc is offline
Radio wiring harness guru
Nice write-up.
Attached is a PDF version I made (using the PrimoPDF print-to-PDF converter).
See my SVX Audio Installation Guide for detailed instructions on removing the radio as well as running wires under the carpet next to the transmission hump.
The "power antenna" lead is usually not a good choice to use as a remote-on for an amplifier, since most radios only activate this lead when you listen to AM or FM (and turn it off when you switch to CD, tape, satellite, etc.). If your radio doesn't have an amplifier turn-on lead, you should use the +12V Accessory (key-switched) wire.
David C.
