Old 08-07-2006, 09:04 PM
92SVXLS-LDC's Avatar
92SVXLS-LDC 92SVXLS-LDC is offline
my new sti 6disc...
hey there guys... i picked up a brand new sti 6disc from a guy stripping his car for rally... after a painful day of install, here it is! ohh the last trim piece isnt on yet, but you get the idea...
how many of you have the 05-06 stereo?? besides me of course
heres it is in the light
and dark!!
'96 Saab 900 turbo
'95 Passat (drove the wheels off)
'92 SVX Ls-L (smashed/sold)
'88 Acura Legend (wheel fell off)
'90 Audi 80 quattro (50mph into side of truck)
'95 Saab 9000cse turbo (sold)
Old 08-07-2006, 11:01 PM
Crazypolo95 Crazypolo95 is offline
95pologreen
Send a message via AIM to Crazypolo95
That rock man. Now i wanted to put one in my car. Anything Add things you had to do to make it fit in ?
Old 08-07-2006, 11:18 PM
Looks great. It sounds like it wasn't a very easy install.
Old 08-07-2006, 11:21 PM
Speedklix's Avatar
Locker Link Solution
I don't get what would be soo hard about it. Other than first time installing a stereo of course. Nice upgrade. I've seen a bunch on here, so give it time, they'll probably chime in.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 08-08-2006, 06:47 AM
well, it wouldnt have been very difficult, except for the fact that i dont have a lot of tools, and things down there are sharp...
-i ended up cutting the whole back of the cage off...
-then i cut out a support bar bar/plate type thing cause it was blocking it from fitting flush
-then i had to melt the inside part of the door to facilitate the bigger knobs,
-and the black trim had to be cut to get back in there with the bigger knobs..
i got a heck of a deal ($75 shipped) from nasioc, most of em go for 'bout 100 though, and overall i think i'm very happy with the install...
(oh, and i had to go back twice to get a stupid antenna extension cable.. the first one broke?!(30miles each way))
'96 Saab 900 turbo
Old 08-08-2006, 11:47 AM
Speedklix's Avatar
You shouldn't have to. Just put it in before you pop that black piece back on to the back of the door.
-Mike
[SIGPIC][/SIGPIC]
Old 08-08-2006, 12:08 PM
thats what i had planned... (to be honest, the square trim piece hasnt been cut yet, but i have it all ready to be...) and i couldnt for anything get both in at the same time... (back of the door piece and trim piece) i could get either one of them in by themselves no problem, i was workin in the dark, i'll try again today...
oh!, and anybody doing this, should disconnect their battery before trying it... or else you'll blow a fuse...
'96 Saab 900 turbo
Old 08-08-2006, 12:17 PM
Speedklix's Avatar
just take your time the trick is to swing the door up to get the back piece in. You just need to be patient and play with it for a bit. Remember how you took it out in the first place
-Mike
[SIGPIC][/SIGPIC]
Old 08-09-2006, 11:53 AM
SVXer95 SVXer95 is offline
Word to Yo Motha
IIRC, the only modification I made when installing mine was to remove the back of the stereo cage. All other pieces fit fine with no modification. I ground down the piece that fits to the back of the door to accept the knobs, but later determined that wasn't necessary.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 08-09-2006, 12:33 PM
maybe yours was different? i definately needed to take out a a piece from inside the dash, and the inside of the door needed to be modified(melted in my case), the trim peice however, does not... is yours an 06 sti head unit?
edit... just checked your locker... looks the same... (weird)
'96 Saab 900 turbo
Old 08-15-2006, 05:32 PM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
The plugs in the back of my 6disc didnt match up at all with the connectors that went into my svx unit. Did you guys rewire the connectors?
[SIGPIC][/SIGPIC]
Old 08-15-2006, 06:17 PM
svxdc sells harnesses that you can use to mate the new stereo with the SVX connector.
Old 08-15-2006, 06:26 PM
Old Fogey
See SVXdc for wiring harness adapters. Requires 2 to make this work without butchering the stock wiring.
Mine, while not an Sti 05-06 model was as new and did require modification of the rear of the door to fit over the knobs. A very nice upgrade, although I think the diversity tuning of the OE may have actually been superior.
Glenn
Old 08-15-2006, 06:59 PM
jman050's Avatar
Its a Classic!
By svxdc do you mean the thread starter?
[SIGPIC][/SIGPIC]
Old 08-15-2006, 07:30 PM
jman050's Avatar
Its a Classic!
nevermind i found him
[SIGPIC][/SIGPIC]
