Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Audio/Video/Nav/Security
Old 06-10-2008, 10:47 AM
processengr's Avatar
Will this headunit fit?
http://www.crutchfield.com/App/Produ...BB&c=3&tp=5684
Crutchfield says no...depth is only 6.1", factory radio is 6.625". DIN mount. I wonder about the center knob, will it clear the cover? Like the built in bluetooth, CT is a "hands free only" cell phone in car state.
I also like the 728 colors, should find one close to the SVXs dashlight color...
Anyone seen or tried one of these?
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 06-10-2008, 08:02 PM
Jtuck Jtuck is offline
This radio fits any din slot right? cause if that is the case it will fit and all you would have to do is find a universal pocket to put in place of where the factory cd player is...
Old 06-10-2008, 08:08 PM
Speedklix's Avatar
Speedklix Speedklix is offline
Locker Link Solution
ha!
I thought it was 6.25... even better
Either way, you should be good on the back end, but you'll probably have to pull the curved liner off of the door to accomodate the knob in the front... unless you mount the unit on the bottom or mod the liner/insert
...who knows? it may even clear the knob, but I would go with melting the liner a bit (if needed) and keeping the head unit on the top side.
-Mike
ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC]
In progess: track down mystery noise <-identified, paint the new dash, get better pic
Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165
Member #995 | My Locker | My New Locker
Catch you next at: ? Auto-X ?
Old 06-18-2008, 06:40 AM
ridered777's Avatar
ridered777 ridered777 is offline
Finally HAS a 3rd pedal!!
Send a message via AIM to ridered777 Send a message via MSN to ridered777 Send a message via Yahoo to ridered777
Re: Will this headunit fit?
Looks like it'll clear easy.
Just mount it up top as far as it can go, and your little knob should even clear the door. You shoudn't even have to pull of the plastic inside the hide-away door - looks to be a 1-1/2 DIN size.
As far as the websites go, they're clueless about our cars. Crutchfield and Best Buy told me "It won't fit". I said "You're wrong". Guess who has a DVD player in their car?
-Craig
94 LSi 5spd Barcelona Red, 14Xk miles.
Full custom exhaust (Stebro cat-back, custom rest of the way forward) 8000K HID kit from Tom (SVXfiles), Energy Suspension front sway bar bushings, Non-Droopy visors, Race Concepts C/D + Dimpled Rotors, Axxis Ultimate pads,SS brake lines, Bontrager Works #009 (or something like that), stripped interior.
(up next) Full cage, fuel cell, 327 swap
Old 06-18-2008, 10:27 AM
Originally Posted by Speedklix View Post
ha!
Hi all!
The unit is installed, and fit excellent. I used the dc.svx wiring adapter and excellent instructions. You are correct, the factory unit was 6.25", 6.625" is the maximum depth of the cage. Although the knob on this unit is in the middle, I still could not install the curved liner and close door without interference.
I want to modify the liner to fit, but don't want to wreck it...what is the method to melt the knob clearance in? If I were to heat a metal rod of a slightly larger diameter than the knob and press it into the liner, I would fear that the plastic would stick to the rod and leave an unsightly finish...
Cheers! Gordon
2018 Tesla M3 30k
Display Modes
