Old 02-16-2017, 12:25 PM
donmac45's Avatar
donmac45 donmac45 is offline
Tick Tick Tick
A quiet ticking sound has developed in my '95
It is not related to revs. It seems to be coming from the area behind the gearstick/radio. I first noticed it via radio interference. It ticks about 4 times a second, and continues with the motor off but ignition on. It is no more obvious from the engine bay side than inside the car. My mechanic could offer no suggestions. Anyone got any ideas? regards DonMac
Old 02-16-2017, 09:42 PM
92 SVX 92 SVX is offline
Re: Tick Tick Tick
Not sure if this is helpful but through the radio generally indicates a bad grounding issue, not necessarily in the radio but somewhere.
Also could indicate a bad coil, though when engine is off you would think it would not be making any more noise.
Old 02-17-2017, 01:55 PM
SVX_MY_BABY's Avatar
Re: Tick Tick Tick
When you say gear shift/radio I presume you mean it's not coming over the speakers.
Peter
Old 02-17-2017, 02:21 PM
SVXandO SVXandO is offline
Re: Tick Tick Tick
Not a mechanic, but to me it sounds like a failing relay of some sort. I have no idea what would be in that area, but presumably it would affect some electrical system. Any other weird effects noted, perhaps sunroof operation or interior lighting?
Truly a shot in the dark.
If you find a cause and a fix, please post your story.
Owen
-Owen
'92 SVX LS-L Liquid Silver 123,600 km (~ 76,800 mi)
-completely stock
Old 02-17-2017, 08:13 PM
Re: Tick Tick Tick
Something stuck in the a/c heater fan? maple seed, pine needle etc.
Peter
Old 02-18-2017, 12:28 AM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
Re: Tick Tick Tick
The a/c heater fan is located on the far right side of the vehicle, above the passenger feet.
Sam
Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners
Old 02-21-2017, 03:39 AM
donmac45's Avatar
Re: Tick Tick Tick
Seems to be coming from smallish grey box under the carpet in the lefthand side front passenger footwell - on the right side.
RHD vehicle. What does the box do? -didnt want to dissconnect to see any numbers etc.
regards
DonMac
Old 02-21-2017, 10:38 PM
Svx95's Avatar
eg33svx95
Re: Tick Tick Tick
regards
DonMac
Given you have a RHD vehicle it alters the location of the modules and timers. I believe for proper identification it would be ideal if you snapped a picture and uploaded for us to decipher.
On a LHD vehicle the only "box" by the passengers feet is the door lock timer and a pair of relays for the blower motor.
-Sam
Sam
