help needed to recharge AC system
The AC system needs to be recharged so I bought a recharge canister at the auto parts store. It says to attach to the low pressure port; where is that located? how can I tell I have the correct port? Has anyone done a DIY recharge and are there problems or advice on performing this at home rather than the $150+ at the garage?
Re: help needed to recharge AC system
I recharged mine years ago. Be sure you use the correct gas......
Next find out what is the low pressure line. Get the kit that has the gage If there is a stop leak one get that If u charge it and it only lasts a few weeks you have a bad o ring. Is the compressor running in AC ? Instructions are quite clear on how to find low pressure side. I ended up paying the money. Well worth it it will freeze me out of the car even at 85 deg out side.
When I was in school I sucked in sports. Then I found out I can buy trophies and now I am great at everything. |
Thanks for the info. The compressor is running. Is there a photo,someplace, that can show the low pressure port on our SVX's?
It's right by the oil filler cap. It should have a light blue cap threaded on it.
Thanks, I'll check it in the morning.
You will see the A/C line and the large bulge right in front of that is a screw on fitting, on mine its screw on because its R12 on new one or converted one it will be a R134a quick fitting, but it will be in the same place either way. you want to be sure not to overcharge there is a sticker that says how much the system uses if your bottle is less then that then your fine you may need to add a little more but if your bottle is more then that you will need to stop it from all going in. |
Reason I said get the gage set. U can watch. Shake the can as it fills. Use gloves trust me on that
Thanks for the advice. Driving in comfort now!
