Old 03-12-2015, 06:05 PM
msg115031 msg115031 is offline
low idle
I have a very low idle and can't find the problem. I check for vacuum leaks didn't find any. not throwing any codes. so what can be the problem? please help thank you
Old 03-13-2015, 10:01 PM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
Re: low idle
What is your definition of a "very low idle"? The SVX can idle down to 600-700 with A/C off. 800ish A/C ON
Sam
Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners
Old 03-14-2015, 07:28 AM
Re: low idle
it sits at the line right above the 0
Old 03-14-2015, 06:26 PM
halistan's Avatar
halistan halistan is offline
Grand Poo-Bah
Send a message via AIM to halistan Send a message via MSN to halistan Send a message via Yahoo to halistan
Re: low idle
you can adjust the idle speed. The idle controller is on the drivers side, just outside the throttle body (under the rear cowl). Just pull the cowl off and loosen the two phillips screws and twist it slightly to adjust the idle (while the car is running of course).
'93 LS-L named "Samantha Victoria Xavier"...Sam for short.
All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter.
