Old 02-23-2007, 03:27 PM
nico i wrx u nico i wrx u is offline
they will fit under a 18inch no problem and they will bolt up to our knuckls your going to need coustom rotors for sure.
also about useing the mitsu stuff i made a mistake the caliper on the mitsu sits closer to the rotor so useing a sti rotor and mitsu caliper will work, but you got to drill the knuckl holes out a little bit.
tom i hope you can get them on you will see when you have them in your hands and start to do it that your going to run in to the same problem. i hope you can make them work i gave up. stick with my gc8 LOL
95 impreza sedan L (aka 91 legacy turbo: ej22t DOHC 22B +400whp@20psi spec-C 6mt RA) hand built by Subaru TecNICO International need i say more.
Old 02-23-2007, 04:39 PM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
if the mitsubishi calipers still didnt fit under the 17 i highly doubt the entire pad was even contacting the rotor....because stock both the sti and evo manage to fit under 17s. unless the mitsu caliper is physically larger than the sti....then that paired with a bigger disc would cause problems.
Tom- what would you need? just one front caliper and disc or both? or a front and a rear
[SIGPIC][/SIGPIC]
Old 02-23-2007, 07:57 PM
svxstarship svxstarship is offline
Nico,
If you are really giving up on it, how much are you looking for?
1999 Audi A8. No more SVX's for now.
Old 02-23-2007, 09:30 PM
i cant type well to explian it all but tom will see whats going on and then he can tell you becuse i know what i did and what other pepole tried to make work and it wont work.
svxstarship no i am not selling them i am putting them to good use on my gc8 i just got new sti wheels to fit on my gc8 also.
i am going to stick the 4pots 2pots on the svx becuse then i can clear a 17inch, for me to explian how to do it it would take for ever.
Old 02-23-2007, 09:56 PM
yeah, plus I have a couple spare hubs at home so it will be easy to take measurements
Old 02-23-2007, 09:59 PM
Just one front caliper and one disk... If you have the rears, send me the backing plate, caliper and rotor and I will make sure they bolt onto our hub. Measurements will allow us to find out what rotors we need or however else we can make them fit
Old 03-01-2007, 11:17 AM
solarsvx solarsvx is offline
Send a message via AIM to solarsvx
can you have a custom made rotors to work to make up the diffrences from the svx to the sti
so a 05+ sti brembos bolt up to the svx its just the rotors were having issues with ?
i thought the evo/sti/350z all used the the same brembos, i thought the part # was the same?
2008 evo x with sss package
430 hp 380 torque stock turbo with basic bolt ons
12.56 @ 109 fully weighted 3,500 lbs
Old 03-01-2007, 11:49 AM
jman050's Avatar
Its a Classic!
apparently the caliper moutning points are slightly different. but we will see, im sending mine to next week so that he can try to test fit.
[SIGPIC][/SIGPIC]
Old 03-01-2007, 01:33 PM
Thats what I am think as well... Who cares if you need 18's you will have a 13.8" rotor
But I could sware that when I mocked the rotor(5x100) and the caliper to my car they were going to fit no problem... I will wait for the Stuff to arive from Jman until I can say more. BTW I need you to send me the pass side caliper and either rotor(doesn't make a difference)
Old 03-01-2007, 04:43 PM
wawazat??'s Avatar
Yeah, I'm still around
Good luck Tom. The caliper mounting points on the SVX are located further outbaord from the center of the hub on the SVX than on the rest of the Impreza/Legacy hubs. I have a set of StopTechs from an '02 WRX buddy that I bolted on along with the matching two-piece rotor. The caliper was at least 1.5" too far off the rotor and the pads just barely clamped the outside edge of the larger rotor. An adapter will be required that brings the caliper IN instead of OUT which is what most BBK adapters do.
Todd
Down to none
Old 03-01-2007, 06:42 PM
jman050's Avatar
Its a Classic!
i wonder if anyone has a picture of one of these brackets that allows the caliper to move in towards the hub? I cant really picture this in my head.
[SIGPIC][/SIGPIC]
Old 03-02-2007, 09:12 AM
that would offset the rotor
Old 03-02-2007, 02:10 PM
jman050's Avatar
Its a Classic!
thanks...yeah thats what i was figuring
[SIGPIC][/SIGPIC]
Old 03-08-2007, 07:02 PM
fasdude fasdude is offline
SVX owner wannabe
Hey Nico.
Is that the 97 Polo Green that was on Autotrader.ca from somewhere in Quebec a few months back? I was seriously considering buying it because it only had 97000 kms. The problem was they were asking way too much for it - $11000 if I recall correctly. If it's the same one, may I ask how much you were able to get it for and what shape was it in. (it was hard to tell the shape of the car from that ****ty picture in the ad). Did it need anything?
Just wondering...
Old 03-13-2007, 07:08 AM
no thats not where i got it from, its a long story. if your looking for one i am going to sell it very soon, all most done my baby.
