Does the SVX have Snap Oversteer?
Thinking about it, the SVX does have understeer. From my experience it's the rears that begin to break loose if you hit the corners too aggressively. Backing off on the gas real quick in that situation in any good handling car with mid engine or low centre of gravity will induce oversteer & snap oversteer in many. I've also read on this forum of a few SVX's that have rolled. I know of 2 locally.
Would like to hear from other members on this one. |
Re: Does the SVX have Snap Oversteer?
I know of someone that worked on an SVX just last year and as they were leaving the driveway and headed down the road, they rolled... Don't know if it was due to oversteer but I do believe so.
Also, I like to drive fast... ALL the time. And when I hit turns going at a decent speed, I feel the rear slipping a bit.. Never been scare of rolling till you mentioned it.. Thanks... lol
not in its stock form... The center clutches should drop most drive to the rear wheels on a fast decceleration. Thus not providing them with any reason to lose traction... It would be incredibly hard to roll an SVX on a flat surface. Too low a center of gravity w/ tires that are not wide enough to provide the traction to let it roll.
Tom |
i can see it....back wheels lose traction, slip to the side, steer it out, then they grip again all of a sudden from other direction, then roll......this is while letting up from when just coming from full throttle to slide.........
1985 Brat GL 138k 91 CRX Si 40k 91 CRX Si 155k 97 SVX Lsi 70k 2003 s2000 91 RT4WD 166K |
My car's pretty stock, and if anything I've only noticed mild understeer.
I also think it would spin before it would roll, but I have yet to test this theory
1992 LSL Pearlie: 108k, 15min/$15 mod, Alternator wiring "upgrade," Power Mode switch, K&N drop-in, 4500k 35w low-beam HIDs, 3000k 35w fog HIDs, lots more planned (pending funds, of course)- 4.44 5spd being at the top of the list. "We laugh at honour and are shocked to find traitors in our midst." -C.S. Lewis |
Now, in non-stock form..... -Bill
Could this happen if your AWD isn't working correctly? Like, what if your AWD only kicks in "every so often" or "when if feels like it"?
Bill and Tom sound dead on with the rolling problem. Too wide a tires and an un-even surface/shift of altitude in a road surface, that's a different story.
I believe the original poster is thinking snap-oversteer as the wrong thing... the fact of the matter is unless the car is RWD you're not going to get snap oversteer. Snap-oversteer is referring to the car all of a sudden spinning out while in a slide that is seemingly stable. It happens in MR cars alot, and older RX-7's are also notorious for it. With the SVX not being RWD it's just about impossible for it to develop snap-oversteer. It would seem the majority of posters on this thread believe snap overtsteer to really be snap "understeer"... that is the car is starting to slide out, and then all of a sudden catches itself, and throws the weight the other way... like on a motorcycle for instance. This could cause it to roll. Snap oversteer makes you spin out... the car wouldn't roll. I've been heavy into the drift world the last few months, so I feel this is one of the few topics I can really weigh in at the moment on.
-Craig 94 LSi 5spd Barcelona Red, 14Xk miles. Full custom exhaust (Stebro cat-back, custom rest of the way forward) 8000K HID kit from Tom (SVXfiles), Energy Suspension front sway bar bushings, Non-Droopy visors, Race Concepts C/D + Dimpled Rotors, Axxis Ultimate pads,SS brake lines, Bontrager Works #009 (or something like that), stripped interior. (up next) Full cage, fuel cell, 327 swap |
Rolling is hard to accomplish I would think. I also drive my SVX rather fast, take turns fast, etc. I have never felt the threat of rolling, but have felt the wheels starting to lose grip going around sharp corners at higher than normal speeds. I feel that it would slide out before it would flip on a flat surface. Now if your sliding sideways and hit a curb or something low that the wheels catch on, you might have the momentum to roll, or maybe hit a smokey and the bandit type ramp, maybe. Regular road, I don't see how it could happen, unless you turned to the left then a hard jerk to the right. Then though seems more like a spin out than a roll though.
