Best sounding exhaust setup?
Just wanna get some opinions on a nice, quiet, rumbly exhaust setup. Post some sound/vid clips if you got em.
Brian |
Well after a year of having the Stebro I can honestly say I love the sound. Most everyone I know likes the sound of the exhaust. Even the tech guys at AutoX and a Subie Salesman complimented me on the note.
I like it because it really does sound like a G35/Porsche. It doesn't drone when driving. When its cold and gets to 3500 RPM it sounds really nice! I'll see about getting a quality sound clip. My autoX videos you can kinda hear it but you gotta know which car is which by the position on the track and exhaust note.
1992 SVX LS-L: Now TomStock Stage 3... 6MT, R180 Rear, Tomstock Short Shifter and hard rubber mount, Group N Motor and Tranny Mount, Stage 2V6 Chip, Z32 MAF, Stage 3 CAI, Stebro, Intake Cams, 17" STi BBS Powder Coated Black, Bridgestone Potenza RE070, and Koni inserts w/Mychailo's Springs! Sand Diego SCCA Solo 2 #308 RIP 84 VW Scirocco 02 WRX 88 XT6(regret the day I left her behind) socaleuro.com They like the flat 6... Check My New Homepage.. |
Given the nature of the Stebro and the "BillStock" stock muffler (let's just say it's very similar to the Stebro design), it's almost as if the car sounds best with a large open cavity at the end of the exhaust system. Try 1.625 in OD pipe throughout, a 2 into 1 high flow secondary cat, a high flow resonator (the one Dayle offers works nicely) and the least restrictive muffler you can find - if you can't afford the Stebro muffler. Removing the primary cats will result in a resonance if you don't replace them with some other type of restrictive device (don't use any type of "normal" muffler, as you don't want material flaking out of them and fouling the secondary cat).
-Bill p.s. while I don't have any sound clips of Billstock/Battlestar's exhaust, you can ask TOMSSVX, Benebob, Hoecrest, NEWSVX, etc. who were at the Subaru Challenge as to what they "heard"
1 7/8" piping for the entire system?
I'm also a fan of the Stebro. That's one thing i would definately do to my car if I had the money!
Brian |
You can definitely get stainless pipe in 1.5, 1.625, 1.75, etc. OD.
You can always check what is stamped on the tubing to see if it is SS (303,413, etc.). Run of the mill exhaust pipe will be magnetic (i.e. a magnet will stick to it), lower grade SS (400 series) will also be magnetic, but not as much as plain steel (300 series SS is not magnetic at all)... -Bill
Retired NASA Rocket Scientist Most famous NASA "Child" - OSIRIS-REx delivered samples from asteroid BENNU to Earth in Sept. 2023 Center Network Member #989 '92 Fully caged, 5 speed, waiting for its fully built EG33 '92 "Test Mule", 4:44 Auto, JDM 4:44 Rear Diff with Mech LSD, Tuned headers, Full one-off suspension '92(?) Laguna, 6 spd and other stuff (still at OT's place) My Locker Last edited by SVXRide; 12-16-2006 at 03:21 PM. |
My '95 has the full Stebro system on it and it sounds great! Deffinetly has that Porsche sound. Dont hear it at idle in the car, but gives a very nice thick tone when making trips to redline.
Dustin
-Dustin 1992 Ebony LS-L w/191k miles Mods: a few and acouple more 1995 Brilliant Red L/AWD w/154k miles Mods: Stebro catback exhaust, K&N drop in filter, ECUtune ST1v5, 4.44, lots of JDM goodies 1992 Pearly LS-L w/154k miles Sold Mods: 4.11, rust 2008 DGM Legacy spec.B w/245k miles Mods: Cryotune Stage3, VF52, bushings galore, STi pink springs, Bilstein HDs My Locker The only man alive who drives three "Subu SVS's".......according to my insurance company |
I think mine sounds the best.
It's only loud between 1900ish and 3400ish rpms, and even then the stereo can drown it out.
Shotgunslade,
You are using the camaro style muffler?
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
