Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
Old 02-11-2005, 01:21 PM
angrydan angrydan is offline
Any EcuTune Stage I Install Tips?
Hey guys,
I just ordered my EcuTune Stage I ECU and was wondering if there were any tricks or things I should know to make the install go easier. I will not be using the 87 oct. map, so I won't be installing the switch. I thought I read something about having to remove a resistor or something?
Any insight anyone can add to make the install go easier is greatly appreciated.
Thanks!
Dan Taney
1996 Subaru SVX LSi (Red)
2019 Subaru WRX LTD
Old 02-11-2005, 03:24 PM
BigBlueSVX's Avatar
BigBlueSVX BigBlueSVX is offline
Donate to the mod fund
Send a message via AIM to BigBlueSVX
The instructions are detailed with pictures, so you'll know what to do with the ECU itself. I would suggest first removing the ECU, and then disconnect the four connectors that go to it. With the ECU hanging down its much easier to disconnect them. Other than that the install is very simple and straightforward.
1994 blue FWD Subaru SVX L with 86k and the original tranny *SOLD*
My Cardomain page
Now part of the DSM crowd: 1990 Mitsubishi Eclipse GSX
Old 02-11-2005, 04:45 PM
SubaSteevo's Avatar
No longer blue member
Take yoga classes
-Steve
01' MSM Lexus IS300
Old 02-11-2005, 05:46 PM
Old Fogey
Wash your hands in VERY HOT water in hopes they'll shrink!
Actually, not a tough job at all,......... for a contortionist.
Glenn
Old 02-11-2005, 06:40 PM
rob_4187's Avatar
rob_4187 rob_4187 is offline
You're mine!!
Send a message via AIM to rob_4187
Originally posted by BurgundyBeast
Take yoga classes
Definitely
Teal 92 SVX LS L with 103k
Engine: Stage 1, 3 in filter with heat sheild, underdrive pulley, NOS fogger system (75 shot)to be installed soon Sound:1 10" infinity with 230 continuous watt Dual amp (we have small trunks)
Old 02-12-2005, 12:21 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
1. Read the directions carefully before touching anything on the car,
2. Move the Driver's seat all the way back,
3. Move the steering wheel up as much as you can,
4. Get yourself one of those "miner's light" that you can wear around your head so you can see what you're doing once you're one your back and trying to loosen the bolts holding the ECU in place
5. Make sure the car battery is disconnected - after you move the Driver's seat back.
6. Make sure you've grounded yourself before you start working on the ECU - you don't want any stray static electricity doing a number on the electronics within the ECU.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 07-24-2005, 11:37 AM
pnyklr
Originally Posted by SVXRide
1. Read the directions carefully before touching anything on the car,2. Move the Driver's seat all the way back,
-Bill
Found the directions..good to go
Old 02-12-2005, 06:59 AM
immortal_suby's Avatar
Thread Killah
-Bill
And don't forget to leave the radio door open.
Locker Link
2015 BRZ Limited 6MT
Old 02-12-2005, 10:32 AM
SVXRide's Avatar
Okay, Matt, you've got me on this one
Must be one of those "special" steps I missed in the directions
-Bill
Old 02-12-2005, 10:41 AM
If you have a CD in the player, and the power comes back on, the CD ejects and if the door is closed, it folds the CD down inside of the door. I have not done this yet (knocks on wood) but have heard from many that have.
Old 02-12-2005, 11:00 AM
UT_SVX UT_SVX is offline
livin in AZ
When I received my V4 upgrade one of the chips wasn't programmed. Michael exchanged it quickly without a problem and now the V4 is runnung great. So taking out the ECU for the third time I actually took off the metal plate that is under the steering column and dash(four 10 mm bolts), and it saved a large amount of time in reaching the nuts holding on the ECU. BTW I don't have a TCU.
Darren
"Stand up Strong, Feel the Pain! Till the Angels Sing"
Social Distortion
1992 LS-L Pearl White :Optima Red Top, Motorsports Warehouse drop springs and swaybar bushings, Race Concepts slotted and dimpled rotors ,SS brake lines,semi-metalic brake pads, 4.11 5 speed, STi short shifter and tranny mount, Exedy sport clutch, Kartboy shifter bushings, intake silencer removed, ECU Tune Stage 1 v4
Old 02-12-2005, 03:00 PM
SVXRide's Avatar
Darren
How did you tell that one of the chips wasn't programmed?
-Bill
Old 02-13-2005, 01:08 PM
livin in AZ
-Bill
Magic.
No, I installed the upgrade, then my car wouldn't start after doing a bunch of things I sent it back to ECUTune and then Michael sent it back and told me.
Social Distortion
Old 02-13-2005, 08:11 PM
SVXRide's Avatar
Magic.
Ah, the old "doesn't start after the mod" trick. Glad to hear that things worked out. Michael works hard at customer service....sounds like they just had a little QA issue.
-Bill
Old 02-17-2005, 08:13 AM
I put the chip in last night... my SVX drives like a whole different car now! I love it! I'm sure this goes without saying, but no SVX should be without this upgrade!
I had one more question, though... I am having a HELL of a time getting the ECU box screwed back in. Are there any special tools that make it easier? (Right now I have it duct taped and wire-tied down)
Any help is appreciated!
Dan Taney
2019 Subaru WRX LTD
