Old 02-23-2006, 12:53 PM
jedimike2121 jedimike2121 is offline
What is involved in swapping to a 4.44
Hi guys, I have one more question about swapping to a 4.44 EAT... What exactly is involved in the process?
I was told that something needs to be cut so that it fits in but other than that you just have to change the rear diff and everything else should fit.
Is there an article outlining the process that I can be referred to? I'm looking to have someone from the network come to my area to do the job but if that doesn't happen I will need to explain this process to a regular mechanic willing to do the job. I'd appreciate any help here. Thanks.
-Mike
Old 02-23-2006, 01:06 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
-Mike
Nothing special involved really. The tranny will replace your old one exactly and if you get a rear end that already has a limited slip, then nothing needs to be done there either. It's a direct swap. If you get a rear end with no limited slip, Then you have to put the limited slip from the SVX into the legacy rear end which requires just a little clearance grinding inside the diff case. Good luck.
P.S. contact svxfiles.
