Go Back   The Subaru SVX World Network > SVX Main Forums > Wanted or For Sale
Old 08-22-2005, 12:29 PM
rmjjensen's Avatar
rmjjensen rmjjensen is offline
Send a message via AIM to rmjjensen
Where to get 5 speed PARTS?!?!
WTF?! How did you swappers get all the parts you needed for a swap? Every salvage yard I call has nothing. And you'd think a lot of WRX's would be crashed.
Any ideas or recommended places? - I'm in Northern New Jersey....close to NY
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing
5-Speed Status: DONE!
Lambo Door Status: On hold but will be a success
04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk.
The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash
Old 08-22-2005, 05:08 PM
rmjjensen's Avatar
how does this look:
http://newyork.craigslist.org/jsy/pts/91380463.html
Am I correct in saying the trans in this car is the following:
...1 gear = 3.454
...2 gear = 2.062
...3 gear = 1.448
...4 gear = 1.088
...5 gear = 0.825
...Final = 4.111
Old 08-22-2005, 06:17 PM
You'll be revving pretty high with that kind of gearing. I would recommend finding a tranny with a .738 5th gear.
Old 08-22-2005, 06:19 PM
Manarius's Avatar
Manarius Manarius is offline
Pillage a 88-94 Legacy. You'll have all the parts you need.
-Jason
-Obi Wan Kenobi
Old 08-22-2005, 07:17 PM
rmjjensen's Avatar
Yeah I noticed that too with the 4.11's on that trans I'm just in need to get something going rather quickly. I'd prefer to pick up an 02 (or equiv) late model WRX Impreza. I'd like hydraulic and a trans with little miles. Figure a wrecked 02 would do the job.
Old 08-23-2005, 12:28 PM
It would do nicely and probably the easiest swap IMO.
Old 08-23-2005, 02:36 PM
rmjjensen's Avatar
I think I found something promising ...right in my area:
http://forums.nasioc.com/forums/show...8&page=1&pp=25
Now ....an '04 WRX - nothing fancy right - should bolt up just fine?
Figure I need the following:
Trans
Flywheel (depending on how good/bad this one is)
Starter
Clutch Master Cylinder
slave cylinder
Hydraulic lines
Pedal Box
Shift Linkage
Shifter Assembly
Shifter Boot
....is that all? Anything else I should get off this thing? And what would be a fair price for it all?
Old 08-23-2005, 03:02 PM
mbtoloczko's Avatar
sans SVX
'04 WRX is great. They have the widened 1st and 2nd gears.
Get the tranny x-member also. Its not a direct fit, but it can make a good basis for a x-member that can work.
Mychailo
Visit my locker
Old 08-23-2005, 04:07 PM
rmjjensen's Avatar
That's what I like to hear. What are the exact gear ratios on the 04 trans?? I like doing the RPM/MPH calculations
I sent the guy a PM so hopefully he'll get back to me asap. I don't like seeing the SVX parked....front differential took a **** the other day ...but let's see if we can make some good come of it.
One more question - I remember a thread stating a 98 Outback driveshaft was a drop in fit but people were waiting on confirmation. Was it ever confirmed?
Old 08-23-2005, 05:07 PM
I'd like to know the ratios as well. I did a quick search and found the ratios to be the same for 2002-2004 WRX's.
Old 08-23-2005, 06:38 PM
rmjjensen's Avatar
There's an 04 STi that's been wrecked. The damage looks severe though. Take a look:
http://forums.nasioc.com/forums/showthread.php?t=832187
Do you think the transmission and differentials were able to withstand the abuse? If I got the STi I'd need the Rear differential, correct? Basic installation is still exactly the same to the 5Speed - no?
Old 08-23-2005, 06:59 PM
mbtoloczko's Avatar
sans SVX
Yep, 2002-2004 are same gear ratios.
rmjj, the WRX gear ratios are nicely suited to the SVX motor. If you have MS Excel, PM me with your email and I'll give you a spreadsheet with the gear ratios and mph in a detailed table.
If you are not going to be abusing the car too badly, I'd go with the WRX 5MT over the STi 6MT.
Mychailo
Visit my locker
Old 08-23-2005, 07:56 PM
n00b on demand's Avatar
Mychailo i sent you a PM about suspension. Check your PM box.
Old 08-24-2005, 10:29 AM
Old 08-25-2005, 02:39 AM
NomadTW's Avatar
NomadTW NomadTW is offline
abrasive personality
Send a message via AIM to NomadTW
www.car-part.com is your friend
SV What?
