Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania
Old 12-14-2005, 06:02 PM
clarkgs240 clarkgs240 is offline
HID Craigslist
My friend told me if it isn't phillips or if it doesnt come from a BMW then its crap. What do you guys think? These are at a pretty reasonable price. I'm doin the 9005 silverstar thing right now, but im thinking of steppin up to HID
http://www.craigslist.org/sfc/pts/118185225.html
Old 12-14-2005, 07:13 PM
intelisevil's Avatar
<<<Alcyone
He's offering a "LIFETIME WARRANTY" for lightbulbs?
What's that smell . . . fish?
Just my $0.02,
Dan
Pentiums - Melt in your PC, not in your hand!
Project - '92 Claret - Purchased May '06, 99,XXX Miles. Includes two bad engines and one bad tranny, cracked windshield, otherwise mostly complete.
His - '92 Ebony Pearl - Purchased Dec '05, 134,687 Miles. Parked, TC Seal(?) is leaking.Daily driver - 140,500 and climbing.
Hers - '92 Teal - Purchased Aug '05, 129,050 Miles. Daily driver - 160,000 and climbing.
PWR Radiator!
Problems:
Antenna doesn't work - Bought a 'new' one - Too cold to install . . . OK, it's warmer but I have other projects too!
Ticking from front of engine, passenger side - Stuck lifter?
Old 12-15-2005, 12:37 AM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
6k will give you a nice silver light.
OEMs are 4500-5500 if I recall. They are a little more yellow straight on. I made a mistake of getting 8k. They are nice but I could use 6k. Much more light output
Remember, they are not legal till you have a full blown everything. I've covered that more than enough times.
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 12-15-2005, 07:54 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Send a message via AIM to mohrds Send a message via Yahoo to mohrds
and the difference between projector assemblies built for HIDs as opposed to those built for 9006s has also been covered various times.
Conclusion: You can't get serious light without going all the way. Anything else is sacrificing one area to improve another.
Doug
1992 LS Touring (6/91) - Currently undergoing a five speed swap
Black over Claret with spoiler; 235,000 miles; Mods: 2002 Legacy 5 speed, ACT Pressure Plate, Excedy Clutch, Short Throw Shifter, Aussie Powerchip
Black over Claret with 2.5" setback spoiler; 202,000 miles; Mods: B&M Cooler
1994 LSi (4/93)
Bordeaux Pearl; 198,000 miles; Mods: Weight reduction.
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Sola lingua bona est lingua mortua.
Old 12-15-2005, 08:47 AM
what about those HIR bulbs? Anyone have any thoughts on them?
http://www.hirheadlights.com/
Old 12-15-2005, 09:59 AM
mohrds's Avatar
What he is doing is retrofitting a GE9012 (low beam) or a GE9011(high beam) into a 9006 or 9005 socket.
I never trust anyone cutting and soldering my stuff except me.
The 9012 & 9011 have a Light center of 1.25" from the base mount, the 9005 & 9006 have a 1.24" Light center so you would need to shim it .01" to move the filament into the right position.
I would just buy the real 9012 bulbs and replace your sockets and shim them. Then you are not bound to the hack retrofit versions, you can get them for a few bucks at any parts store.
Doug
1994 LSi (4/93)
2000 Ford Excursion
Old 12-15-2005, 10:30 AM
thanks mohrds i was seriously considering getting those bulbs, after hearing that i think i'll pass!
Old 12-16-2005, 01:25 AM
Hey Guys Thanks for the input
So Doug, just to be clear i know there are compromises but for a plug and play system, i'm guessing you wouldn't think this thing is worth the $240.
What would this upgrade be worth to you? With it's light output in the svx housing do you think it would be worth $100. Or would you even pay $50 for this mod. I'm just curious what you think the value of something like this is. It would give me an idea of how much of an improvement it would make.
Thanks
Clark
Old 12-21-2005, 12:04 AM
NomadTW's Avatar
NomadTW NomadTW is offline
abrasive personality
Send a message via AIM to NomadTW
legal where? define legal?
SV What?
Old 12-21-2005, 09:06 AM
mohrds's Avatar
I can't put a price on the retrofits because every one of them involves taking an HID capsule, cutting the base off and gluing it into a 9006 base. Therefore, they hold no value to me whatsoever.
Things I would recommend to improve lighting:
1. Clean the outer lens.
2. Replace the factory headlamp wiring with an upgrade kit like this one: http://suvlights.com/product_info.php?products_id=112
3. Do the 9005 Upgrade
4. If you still aren't happy, replace the headlamps or do the BMW real HID conversion.
One thing to remember is that 10+ year old optics can be as little as 30% efficient as new. With corrosion of the housing and decay of the focusing lens, even throwing a ton of light into it, isn't going to get you any better light output than a new headlamp assembly.
I suspect you won't get past step 2 or three before you are happy with the light.
Doug
1994 LSi (4/93)
2000 Ford Excursion
Old 12-21-2005, 10:56 AM
Seraph's Avatar
OEM systems have HIDs, correct projectors, and leveling system that your car or mine lacks. What does the leveling system do? When you hit a bump, it automatically lower the beam so that you don't shine that high lumen output light into the oncoming traffic. Safety thing.
Current SVX: NONE
Old 12-22-2005, 12:09 AM
NomadTW's Avatar
there is no such restriction in PA, and i'm sure that there is no such restriction in other states. the only rule about headlights in PA, is that they have to turn on, turn off when the other beam comes on, and not deviate more than 4" from centered.
www.pacode.com
SV What?
Old 12-22-2005, 12:20 AM
Seraph's Avatar
www.pacode.com
They are in the IL vehicle code. The thing is about 400 pages long and it tells you in detail how high the light should be, how many lumans it can out put. Which beams are allowed etc in very FINE detail.
Current SVX: NONE
Old 12-22-2005, 12:31 AM
NomadTW's Avatar
then you need to specify that you are talking about IL, and not make brash generalizing statments implying that because it's true in your state that it applys to everyone else
SV What?
Old 12-22-2005, 03:19 PM
AppStateSVX's Avatar
AppStateSVX AppStateSVX is offline
Mountaineer
Send a message via AIM to AppStateSVX
while it might be legal to do such things in other states, is it worth the risk of a potentially dangerous situation for other drivers?
1992 Midnight Black LS-L - Sold 3/3/06
1991 Toyota MR2 - Sold 11/27/07
1992 BMW 325i
- Tokicko Suspension
