Where to get 5 speed PARTS?!?!
WTF?! How did you swappers get all the parts you needed for a swap? Every salvage yard I call has nothing. And you'd think a lot of WRX's would be crashed.
Any ideas or recommended places? - I'm in Northern New Jersey....close to NY
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing 5-Speed Status: DONE! Lambo Door Status: On hold but will be a success 04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk. The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash |
how does this look:
http://newyork.craigslist.org/jsy/pts/91380463.html Am I correct in saying the trans in this car is the following: ...1 gear = 3.454 ...2 gear = 2.062 ...3 gear = 1.448 ...4 gear = 1.088 ...5 gear = 0.825 ...Final = 4.111
You'll be revving pretty high with that kind of gearing. I would recommend finding a tranny with a .738 5th gear.
Pillage a 88-94 Legacy. You'll have all the parts you need.
I think I found something promising ...right in my area:
http://forums.nasioc.com/forums/show...8&page=1&pp=25 Now ....an '04 WRX - nothing fancy right - should bolt up just fine? Figure I need the following: Trans Flywheel (depending on how good/bad this one is) Starter Clutch Master Cylinder slave cylinder Hydraulic lines Pedal Box Shift Linkage Shifter Assembly Shifter Boot ....is that all? Anything else I should get off this thing? And what would be a fair price for it all?
'04 WRX is great. They have the widened 1st and 2nd gears.
Get the tranny x-member also. Its not a direct fit, but it can make a good basis for a x-member that can work.
That's what I like to hear. What are the exact gear ratios on the 04 trans?? I like doing the RPM/MPH calculations I sent the guy a PM so hopefully he'll get back to me asap. I don't like seeing the SVX parked....front differential took a **** the other day ...but let's see if we can make some good come of it. One more question - I remember a thread stating a 98 Outback driveshaft was a drop in fit but people were waiting on confirmation. Was it ever confirmed?
There's an 04 STi that's been wrecked. The damage looks severe though. Take a look:
http://forums.nasioc.com/forums/showthread.php?t=832187 Do you think the transmission and differentials were able to withstand the abuse? If I got the STi I'd need the Rear differential, correct? Basic installation is still exactly the same to the 5Speed - no?
rmjj, the WRX gear ratios are nicely suited to the SVX motor. If you have MS Excel, PM me with your email and I'll give you a spreadsheet with the gear ratios and mph in a detailed table. If you are not going to be abusing the car too badly, I'd go with the WRX 5MT over the STi 6MT.
Mychailo i sent you a PM about suspension. Check your PM box.
www.car-part.com is your friend
SV What? |
