Old 05-17-2007, 02:28 PM
jeffast jeffast is offline
I kill more trannies then god
knock sensor
ok my car keeps throwing knock sensor #2 as a code what are my odds of finding a good one in a junk yard. how hard is it to pull the intake plenum, and do i really have to and if so how hard is it to find gaskets, and what t=do they cost,
thanks
jeff
1991 xt6 eg33?
1993 gc track car
Old 05-17-2007, 02:51 PM
I don't know about finding one in a junk yard. Not many ever seem to have an SVX at least around here, but you might be able to find a good sensor off another member on here. If you do buy a used one I would just try and make sure it is off a low miles car. If I remember right there is a resistance check you can do to make sure the knock sensor is good. I just don't remember the specs. I replace both of mine awhile ago and the only thing I removed was my alternator and the H-6 engine cover so you don't actually have to remove the intake manifold. You just need a few extensions and a wobbly socket. I actually just bought those gaskets about a month ago from my local dealer. He had them in stock and I think I paid like 7.50-8.50 a piece. Hope this helped.
Old 05-17-2007, 04:38 PM
Dza's Avatar
Dza Dza is offline
#073 of 301
I got mine for around $50 each from Subaruparts.com. I've seen many recommendations that you replace both at the same time, so I went with that but I am not sure that it is necessary. Mine were both old and busted originals so I'm glad I did. Since they age poorly and go on many SVXs, even if you found an SVX at a nearby junkyard the sensor may not be in good shape.
Here's the price from subaruparts.com and the part #:
22060AA031 Knock Sensor $53.96
Dan M.
Barcelona Red '93 AE #073 of 301, 168k miles.
Old 05-17-2007, 09:46 PM
ok i think i'm looking at the wrong thing then, can someone post a pic or diagram of where the sensors are, and i know where 2 svx's are in a yard near me,and at $4.00 a sensor i can afford a few duds, i would prefer to go new but replacing both new would be 1/13 of what i have totally invested in this car
1991 xt6 eg33?
1993 gc track car
Old 05-17-2007, 10:03 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
check my locker (). I replaced both of the knock sensors a while back.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 05-18-2007, 10:33 AM
thumper_svx's Avatar
thumper_svx thumper_svx is offline
Either committed, or should be
Send a message via ICQ to thumper_svx Send a message via Yahoo to thumper_svx
I also got my knock sensors from subaruparts.com... I think it was about $40 each or something like that. Anyway, I'd just buy a pair of new ones and do it yourself.
You can do it without removing the intake plenum, but you need small, steady hands and a small 10mm wrench. You also need the patience of a saint. I did it, but the rear knock sensor was a bear to get back in; getting it to stand upright, get the bolt into the threads and tighten it down one-handed in VERY confined spaces was tough, but it's doable. I also have skinny hands
Note that to get the sensor out with the 10mm wrench, you'll maybe be able to turn the bolt 1/4 of a turn then have to reposition the wrench with very limited headroom. You'll also maybe get the bolt out 2/3 of the way before you can no longer get the wrench in there... then it's fingertips twirling the bolt until it pops off.
Took me about 90 minutes in total to replace both through the opening after removing the alternator. You might get more clearance if you remove the A/C compressor and move it to the side as well, but I didn't want to mess with all those aluminum hoses!
Ich bin ein SVXer wieder
My Rides:
Red 1996 SVX LSi (Saffron)
2007 Yamaha FJR1300 (Kaitlin)
Previously owned; green '95 L AWD (sold), black/pearlie '94 LSi (too many problems), Polo Green '96 SVX LSi (apparently notThe end of an era)
Member #2 in the Yahoo! club, been here since the beta-testing days. In dire need of a cheaper hobby.
Old 05-18-2007, 12:24 PM
green_eyed_lady's Avatar
green_eyed_lady green_eyed_lady is offline
comparable parts (used)
We have a 1995 motors manual and it states that the knock sensors from the SVX are identical (same part number) as the '95 Impreza (2.2 L engine) and the '90-'95 Legacy. Original Part Number is 22060aa030, which has been allegedly superceded by Part Number is 22060AA031.
There may be other (later) models that match, but our book only goes to 1995.
Legacys and Imprezas are much easier to find in salvage yards than SVX's.
Diana
1992 Liquid Silver LSL, >230K -- "Silver Bullet" // dimpled/slotted rotors, SS brakes lines, 5000K HID headlights // TRI-TONE paint
Old 05-18-2007, 02:21 PM
-Bill
thansk that was what i needed, i'll probably pull the intake plenum when i get around to it the ohm rating on the sensor should be around 560kohms, thanks off to the yard with a meter
1991 xt6 eg33?
1993 gc track car
Old 05-19-2007, 02:06 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
I got mine at autozone for 38.00 a piece... it might pay just to get a new one so you'd never have to go through the agony of replacing them again if the salvaged ones went bad.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 05-19-2007, 02:38 PM
i'm really hard up for money right now, i have $200 a month for gass car parts and food, so thats way outta my budget
1991 xt6 eg33?
1993 gc track car
Old 05-20-2007, 11:16 AM
alltrac alltrac is offline
I think you might be driving the wrong car for your needs. SVX's don't like budgets and love premium gas.
Victor
Old 05-20-2007, 06:59 PM
thats why i have 2 spare cars, i can afford a little down time while saving up for repairs
1991 xt6 eg33?
1993 gc track car
Old 08-28-2007, 10:36 AM
SVXdc's Avatar
SVXdc SVXdc is offline
Radio wiring harness guru
One of my knock sensors just went bad (getting a CEL), so I'm now shopping for them.
The newer 22060AA031 does indeed supercede the older part.
According to the parts search at SubaruGenuineParts.com, this same part number is also used in:
  • Impreza 1995-1996
  • Legacy 1990-1996
  • SVX 1992-1997
Current prices (8/2007):
  • SubaruGenuineParts.com $52.67 (old P/N redirects to new)
  • SubaruParts.com $54.83 (both old and new P/Ns)
  • Advance Auto Parts lists three:
    1. $43.99, Niehoff Ignition Detonation (Knock) Sensor, P/N WA1709
    2. $86.99, Standard Motor Products Ignition Knock (Detonation) Sensor, P/N KS86
    3. $98.80, GP Sorensen Knock Sensor, P/N KS86
  • AutoZone lists two:
    1. $34.99, Wells / Knock Sensor, P/N SU4988
    2. $34.99, Duralast / Knock Sensor, P/N SU4988 (yes, same # as above)
David C.
Old 08-28-2007, 10:54 AM
  • Impreza 1995-1996
  • Legacy 1990-1996
  • SVX 1992-1997
www.rockauto.com has it for $37.79 I also have a code that anyone can use to get an additional 5% off of your total order.
Thank you for being a www.RockAuto.com customer! To show our appreciation, we have a special discount for you.
Your discount code is:
712860639911
Here's how to use it:
* Enter your code in the "How did you hear about us" line of the shopping cart.
* If you are using our traditional HTML catalog, please click the "Set" button to the right of the field.
* Your discount will automatically appear, subtracted from your order total.
**NOTE: We sometimes get calls from people who put the word "discount" in front of their code and do not get the discount. Please enter ONLY the discount code, no other words or numbers.**
The discount takes 5% off our already-low prices, and there's no limit on order size or the number of orders. Use the code for your next order, and share the code with friends, neighbors, relatives, the guy at the corner garage--anyone you know who works on cars or trucks.
This discount code expires on September 11, 2007; so don't wait!
Old 03-12-2008, 12:14 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Code 22
When I start the car cold the CEL light comes on until the engine builds up heat. It's also sluggish on acceleration. Once the light goes out the car performs normally all day.
The stored code is 22, right side knock sensor. I guess I'll just replace both as recommended but could the sensor be detecting something else? I always run on Shell 93 octane.
Gene
Gene and Ben
