Main catalytic convertor help...
My 22 year old cat is buzzing to the point of annoyance now and pinpointed this is the noise source, not the many heat shields. Due to it's "pancake" form with heatshield above, it looks like the universal round ones might be problematic as far as fit. Anyone have the dimensions/source for a replacement cat that can fit in this space without removing the shield or worrying about the drive shaft clearance ? Don't want to just replace with a straight pipe. Any flat cats like the OEM on the market ?
Thanks in advance... |
Re: Main catalytic convertor help...
MAGNAFLOW 94007
Never a fitment or clearance problem. Heat shield can remain. Sxvfiles has done this setup numerous times , including my 92 and 96.
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 07-23-2013 at 09:21 AM. |
What took you so long with an answer !! Great...I see they have these on eBay with free shipping and even a "best offer" option. Off to order one...
Much appreciated as usual... |
Just noticed I am an idiot..it is the distal resonator, not the cat in front of it, that was the "buzzinator". Same question but different part needed..a "flat" resonator if they exixt. Sorry for my confusion.
I've got the same problem... considering just having a muffler shop replace it with a piece of straight pipe. Has anyone done this or have a good suggestion for a replacement?
1996 SVX LSi : Work in progress, future garage queen 2013 Acura TSX: Mistake |
Hope this helps...it's the way I'm going for around $65.00 total cost and being able to connect without welding which I have the capability of doing myself..Svxcess's system, per him, is solid with these excellent band claps and it gives you the ability to remove at least the posterior part of the exhaust w/o unbolting the whole setup. BTW, SVXcess..sent you a PM... |
The straight pipe is worse. You will get an annoying resonance (droning) at highway speeds. You need room for the exhaust gases to expand after exiting the converter.
Do a search here. The AR25's are a good bet. Ask svxfiles, who has done more SVX exhaust systems than anyone. .
Alexander (Norway) My subarus: 1992 Svx LSI 5-MT(3.54) 1998 Legacy BG 2.5L GX |
No. They are AeroTurbine AR20 resonators. They can be used to replace the original pre-cats in the 1992-1995 OBDI cars without problems. No CEL, etc.
They do not work well on OBDII cars; the system is more sensitive and needed pre-cats to keep the CEL off. After these photos were taken, I removed the resonators and replaced them with small Magnaflow converters. No problems since. Magnaflow 99204HM .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 07-23-2013 at 02:59 PM. |
In an OBDI car is it ok to remove the pre-cats all together or do they need to have something else put in place?
1992 SVX Pearlie: AmsOil signature synthetic 10w40 and Ea15k20 filter, Cobb crank pulley, Outlaw Engineering spacers and tb bypass, LGT 5spd, Slotted Crossdrilled rotors and ceramic pads, 11:1 compression, EGR delete, Port & Polished heads, SaikoMichi catch can, A/c delete. |
