4.11 swap shifting, different problem
my car likes to redline the living **** out of second, it wont shift out of second unless i let off of the gas down to less than 2/3 of the way depressed, if i floor it it will down shift even when its past the redline and jerk the car to a lower speed it only does this with second, any ideas?
1991 xt6 eg33? 1993 gc track car |
What is involved with this ---- 4.11 swap ----- with valve body shift kit
Have you checked for codes? Check the TPS. Go a little easier on your car.
the tps is set dead on at 5.2 volts and i keep forgetting to check tcs codes, i'll do it tommorow
OK. You have checked the TPS set position, but your fault is more likely to result from erratic contact at the upper end of travel. Have a look in my locker for more advice.
Was the fault noticed a short time after the transmission work? Have you asked your trusted shop about the problem?
Yep, Jeff,
I'd ask the guys at the shop that installed the shift kit, as it could be related to it, before I'd try anything else....asking them should be free, since it's concerning work they did.
they said it shouldn't affect shift points,
edit: i bought the car with a blown transmission, it had been sitting for a year or more in a field, it had first and reverse when i started working on it, and i found a 4.11 trannie cheap
