Old 09-07-2010, 11:12 AM
Alex-svx's Avatar
Alex-svx Alex-svx is offline
Exclamation Help to coneck Speed senor. (need wiring diagram)
Is someone that can help me to get the speed sensor wired rigth up?
I have the stock transmission contac this one.
And now i need to conect the US speed sensor this i have take from a outback tranny and the sensor is cut off. And its have white and black wire.
(The contac i have is from a european car)
Alexander (Norway)
My subarus:
1992 Svx LSI 5-MT(3.54)
1998 Legacy BG 2.5L GX
Old 09-07-2010, 12:05 PM
Alex-svx's Avatar
Re: Help to coneck Speed senor. (need wiring diagram)
I have find a other topick that i see the speed senor on the contac but.
http://www.subaru-svx.net/forum/show...t=50185&page=2
But the stock speed senor is conect in 3wiers if i understad this right.
white+blue white stripes + black yellow stripes.
And all this go up to this one.
Is it this wire i should coneck the wire form the us-speed senor?
This one this have only 2 wieres
This is to get my manual tranny to read speed.
Alexander (Norway)
My subarus:
Old 09-08-2010, 04:19 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
AFAIK it is not compatible. You must use a 3-wire sensor for this ECU.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 09-08-2010, 09:44 AM
Alex-svx's Avatar
Ok so the i have to get a other from a Europan car? But this i can just wired up to the OME tranny contact?
Alexander (Norway)
My subarus:
Old 09-10-2010, 11:29 AM
Alex-svx's Avatar
I have maybe get one now.
This is from a impreza 99.
Alexander (Norway)
My subarus:
Old 09-10-2010, 03:24 PM
b3lha's Avatar
Phil & Belha
Install the SVX 3-wire speed sensor in the 5MT gearbox.
pin 1 (YR) is the signal wire.
pin 2 (BW) connects to ground
pin 3 (RW) connects to 12v
Remove the YR wire from pin C6 of the TCU plug and connect it to the signal wire of the speed sensor.
Old 09-11-2010, 06:45 AM
Alex-svx's Avatar
Ok thanks alot. I sit and wait for the answere on the speed senor.
And i hope i get it fast. But thanks fore helping me.
Alexander (Norway)
My subarus:
Old 09-15-2010, 08:36 AM
Alex-svx's Avatar
Is it somebody here that have one for sale?
I dont have get one yet.
Alexander (Norway)
My subarus:
Old 09-15-2010, 09:41 AM
Are you looking for a stock US speed sensor with 3 wires?
Old 10-04-2010, 10:52 PM
Alex-svx's Avatar
Is it some one here that have the wiring for this?
I just have the sensor. And not the contakt whit the wiring on.
Alexander (Norway)
My subarus:
Old 10-05-2010, 04:39 PM
Alex have a look at this post. It talks about the way to connect the US speed sensor up, using the VTD TCU. Phils scan is the US connection that you need to do, to get the sensor to drive the speedo.
http://www.subaru-svx.net/forum/show...7&postcount=15
Old 10-06-2010, 09:54 AM
Alex-svx's Avatar
Thanks for posting oab_au
But my problem now is i just have this part in My transmission now
(note this is a US one)
But to get this work i need one of these.
(note just the 3wired one)
And this part i have try to get, but seen that no one have it.
Alexander (Norway)
My subarus:
Old 10-06-2010, 04:27 PM
Alex you mean that you just need the 3 pin wiring plug, that plugs on to the US speed sensor?
Old 10-06-2010, 10:35 PM
Alex-svx's Avatar
Yes thats rigth. But i dont have the US speed sensor. will this fit then?
Alexander (Norway)
My subarus:
Old 10-06-2010, 11:02 PM
OK, we'll get there mate.
Do you need a US speed sensor?
Do you need the plug, with some wire, for the US sensor?
Yes it will work, Huck said so.
