Old 09-02-2010, 12:31 PM
Huskymaniac's Avatar
Uses the ignore feature
Re: Good lord, now it's the air conditioner!
OK, here is an update on issue #3.
I did do the diagnostic on the system and it did throw an error 13 which, I believe, is the sun sensor. Funny thing was that it didn't show the error at first and I only saw it because it was taking me so long to read through the service manual. It popped up after a couple of minutes. This might be affecting the behavior of my A/C but it wasn't causing the shutdown issue.
The A/C wasn't engaging because the coolant was low and it was low because one of the o-rings on the top of the compressor was leaking. I was happy to hear that the compressor was not dead. While I was waiting for my car, the parts guy delivered a compressor for a Buick they had in the shop. I told my kids, "I hope we won't be ordering one of those". We won't be...yet.
Old 09-02-2010, 12:32 PM
The sun sensor will always throw a code unless the car is sitting in direct sunlight...
Originally Posted by Wikedjuggalo View Post
Most likely a freon leak. Get yourself the kit that has the dye and put it on the lower side pressure following instructions. The kit should come with a pressure gauge, will at least tell you if you have pressure or not.
This is fine so long as your car is not using the old R-12. 94+ are fine and 92 that has been converted is fine too.
My leak was right on the compressor where the low side pressure line connects. Price was like $2 for a set of o rings (only needed one of out it).
You nailed it!
Old 09-02-2010, 03:20 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Originally Posted by Huskymaniac View Post
You nailed it!
Pfffff.... well I AGREED with him.......
post 1UP
Old 09-02-2010, 08:17 PM
Wikedjuggalo's Avatar
Rebuilding
You nailed it!
you are welcome, Freon is easy to check along with fuses but if mine did the same thing as far as ice cold and then not working
