Old 07-26-2010, 01:20 PM
92_LSL's Avatar
92_LSL 92_LSL is offline
oil leak
i have oil leaking from the right side of the timing cover. also what are the two large bolts on the bottom front of the engine.
I has teh FWD LS-L
Old 07-26-2010, 02:49 PM
immortal_suby's Avatar
Thread Killah
Re: oil leak
Leak from the timing cover is usually cam seals and/or crank seal (front main seal) In your case probably cam seal but it's a good idea to replace both cam seals and the crank seal if you do anything.
The 2 large bolts on bottom front are on the bottom of the oil pump and are plugs. They are not normally used on the svx.
Locker Link
2015 BRZ Limited 6MT
Old 07-26-2010, 08:33 PM
92_LSL's Avatar
Re: oil leak
thanks alot i'll check that out.
I has teh FWD LS-L
