Re: Bouncing Rev Counter
Thats the coolant temperature sender, it controls the reading of the gauge in the dash.
Just about to replace it now. I'm going out to go get a deeper 19mm socket. I tried the crow's feet spanner that I used for the PCV value but there wasn't enough room for movement. So just for the record a deep 19mm socket will do the trick.
Sorry to keep asking so many questions. Why did this sensor fail? My svx has only 155,xxx kms.
I appreciate all your help on this matter mate |
Its not really a matter of mileage..... more of an age issue. Most thermistors tend to fail after some length of time or # of cycles, it just happens. |
Did replacing the temp sensor fix your bouncy idle at startup?
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
probably not...
I have one SVX with 200,000+ that has never needed one... Keith |
Bump...
I would like to know if it fixed it as well, mine does the bouncy idle every once in a while. I will check my codes tomorrow for the temp sensor. but I KNOW that I have o2 sensor code.
-Steven 1992 SVX Purple and Black 5 speed swap SOLD *1993 SVX Silver and Black *1994 SVX L Barcelona Red FWD |
bought engine temp sensor... gonna find out now... 4 months later...
Worked like a champ, no more hard starts and no more bouncy rev counter!
