Old 07-22-2010, 06:56 PM
IceBlade's Avatar
IceBlade IceBlade is offline
Send a message via MSN to IceBlade
Car's been sitting awhile.. couple questions
Hey, guys long time no see.
My SVX has been sitting awhile and yesterday I tried starting it up and nothing. No power to anything. I check under the hood and the negative terminal to the battery is full of corrosion. It snapped off when I tried taking it off. The ground wires were corroded a good inch into the plastic casing as well. Anyways I checked the fuses and the fusible link was blown. Went to the autoparts store and they want to charge me $10.
So my first question. In my searching someone mentioned as long as I use the same gauge and same length wire and just attach it to the leads that it'll work fine. Is that true? If so what gauge wire is it and what else should I know so I can buy some wire? Do I need to know the amperage it's rated at or something?
Umm secondly I think it might be a good idea to replace some of those wires. Can I buy generic wire to replace the positive wire to the starter and just use the same connection to the starter? Can I do the same with the positive wire to the fuse box as well as the ground wires? If so what do I need to know when buying the wire? I have a stock alternator as far as I know.
And while I'm doing that are there other wires at the same gauge, amperage or w/e that I could replace at the same time?
Oh one last question! Since the car hasn't been started in awhile is there anything I should be looking out for once I finally get it going?
Would appreciate any input!
Old 07-22-2010, 08:38 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: Car's been sitting awhile.. couple questions
Basically replace any corroded wiring with new wire of lesser or equal gauge (greater thickness). I would just dish out the ten bucks for the fusible link.... you can make one that would work but theres no telling what amperage would open the circuit, meaning you may fry something important.
Also, if it has been sitting more than a few months, change the oil before starting it.
Old 07-22-2010, 08:41 PM
Get a new fusible link from Subaru, I believe about $5.
Get some 4 gauge wire to replace the ground and power wires. Sometimes welding supply shops will have it at a lower price, otherwise use car audio wire.
It would be a good idea to change the oil, fuel filter, if possible siphon the old gas out and put fresh in.
answers above in red. Some may have more to add.
Old 07-23-2010, 06:44 AM
IceBlade's Avatar
Thanks, guys.
How do I connect the new wire to the starter?
